Correct Voltage Readings On A 120v Circ. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-06-2011, 11:55 AM   #1
Question
Correct voltage readings on a 120v circ.
I have been all over the net trying to find a simple answer, hopefully i can get it here. i am a former navy electrician so that makes me about 70% proficient in civilian electrical theory.
i have a problem with a dishwasher and a garbage disposal on the same line, that suddenly stopped working. with a non-contact volt reader (wand type, flashy and ringing stick) i am picking up potential at the actual buttons of the dishwasher and to the actual connections of the garbage disposal (both with the disposal switch 'on' and 'off' earlier in the circuit). i know that this is not an accurate way to troubleshoot, i need to disconnect the leads and measure the voltage of the hot, neutral and grd lines at each of the junctions in this system in order to isolate the fault.
my question is what should the normal volt reading be for a 120v typical circuit:
hot to grnd
neut to grnd
hot to neut
with this info, i should be good to fix the rest, thx for the help!
stress78 is offline   Reply With Quote
Old 04-06-2011, 12:01 PM   #2
Licensed electrician
Rewards Points: 1,892
Hot to neutral or hot to ground should be around 120v. Neutral to ground should be 0.
stress78 (04-06-2011)
Old 04-06-2011, 01:21 PM   #3
Generally as above but 120 volts + or - 10volts
hayewe farm is offline   Reply With Quote
The Following User Says Thank You to hayewe farm For This Useful Post:
Old 04-06-2011, 01:56 PM   #4
ok, problem solved... the CB needed a good 'ol re-seating. traced the line all the way back to the main breaker box, pulled the bkr, did a continuity test on it, and plugged it back in, hooked up the line and wala, 120v across the hot/nuet leads in the original j/c box. good to go! thx for input!!
Tags
120v , curcuit readings , hot nuetral ground , readings
Help - can't find the correct low voltage lighting transformer Sherm Electrical 3 03-24-2011 09:21 PM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 06:48 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
