Correct Screws For Mounting Box To Joist? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 09:06 PM   #1
Rewards Points: 14
Correct screws for mounting box to joist?
I have a surface-mounted box that was nailed to the joist in the basement. The box has a duplex receptacle in it. When I unplugged a light fixture from the box to move it, the box came with the plug.
I would rather not try to re-nail the box, as there are wires INSIDE the box that I'd like to avoid w/ a hammer.
So I'd like to use screws.
Would screws be okay? Is there a preferred type of screw for this application? Does code say anything about this?
Sorry for the dumb question.
cgallery is offline   Reply With Quote
Old 04-11-2010, 09:13 PM   #2
Master Electrician
just use woodscrews....make sure they bite into the wood at least an inch. That's just my personal preference...not sure if there's an actually rule for it.
andrew79 is offline   Reply With Quote
Old 04-12-2010, 12:48 PM   #3
gmhammes's Avatar
I just use 1-1/4 drywall screws course thread.
gmhammes is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
correct joist size for attic helpless handyman Building & Construction 1 07-05-2006 11:29 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 02:02 PM
