Is This Correct Regarding 20amp Circuit And 15amp Receptacles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 09:15 AM   #16
Family Handyman
Originally Posted by joed View Post
By code the door bell transformer can't be on the circuit in option 1.
So its best to use option #2 ?
diymonkey is offline   Reply With Quote
Old 04-08-2009, 10:38 AM   #17
Originally Posted by diymonkey View Post
I compared the wire gauge to some #14 wire I had laying around, it looked bigger.
Keep in mind that older 14g (and #12 too) wire is thicker then todays wire
The jacket of the wire should be labeled
Old 07-26-2009, 06:57 PM   #18
Electrical Inspector
Smile
I was told that its standard to put 15amp receptacles on a 20amp circuit as long as its a duplex receptacle and/or more than 1 thing is running on the circuit.
Here is my current config:
20amp circuit breaker
  • 1 switch to wall light in bathroom 1
  • 1 switch to wall light in bathroom 2
  • 1 doorbell
Here is what I want to do
  • 1 doorbell
  • 1 switch to ceiling vent in bathroom 1
  • 1 switch to celiing vent in bathroom 2
  • 1 duplex GFCI receptacle in bathroom 1
  • 1 duplex GFCI receptacle in bathroom 2
So is it true that I can use 15amp GFCIs and switches on that circuit?
You certainly may the only restictions apply to single outlets. That is to say a single device on a single yolk. A GFI receptacle is the same as a duplex receptacle.
Power Up is offline   Reply With Quote
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
Can I use a 20amp outlet receptical on a 15amp circuit? abefroman Electrical 17 01-18-2009 09:57 PM
Attic fan and skylights on same circuit ok? shadango Electrical 7 06-09-2008 02:50 PM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 08:26 AM
