I was told that its standard to put 15amp receptacles on a 20amp circuit as long as its a duplex receptacle and/or more than 1 thing is running on the circuit.
Here is my current config:
20amp circuit breaker
1 switch to wall light in bathroom 1
1 switch to wall light in bathroom 2
1 doorbell
Here is what I want to do
1 doorbell
1 switch to ceiling vent in bathroom 1
1 switch to celiing vent in bathroom 2
1 duplex GFCI receptacle in bathroom 1
1 duplex GFCI receptacle in bathroom 2
So is it true that I can use 15amp GFCIs and switches on that circuit?
Yes you are correct in what you heard. You can put duplex outlets rated at 15 amps on a 20 amp circuit so long as you have more than 1 outlet.
The doorbell should not however be on this same circuit, I would look to see if you can move it to a different circuit. 2 bathrooms on the same 20 amp circuit I believe is "ok" but it would certainly be better if you could put them each on their own separate 20 amp circuit. Other than that, just make sure this circuit(s) do not leave the bathroom area to feed other loads (like the doorbell).
Thanks for the response. Its an old house, so adding a new circuit and running the wire wouldnt be easy. The 1st bathroom isnt used much, so there wouldn't be a load on each bathroom at the same time.
Why would it not be ok to leave the doorbell on that circuit? I could see about moving it to another location, but it seems like its a low power device and wouldn't hurt leaving it were its at.
Not an electrician, but you may service one entire bathroom (outlets, lights..) on one 20A circuit. Nothing else on this circuit. Your other option is to place multiple bathroom outlets only on the same circuit, again nothing else (don't recommend). You may combine bathroom lights on a general circuit.
Just make sure that if you have a heat lamp or similar in the bathroom, see the mfgr. specs if that needs its own circuit.
The bathroom receptacle must be a 20 amp circuit.
There are two senarios.
1. Other items can be on the 20 amp bathroom receptacle circuit IF they are in the same bathroom. The 20 amp circuit can not feed anything outside its bathroom.
2. The 20 amp receptacle circuit can feed other receptacles in other bathrooms. It can not feed anything but receptacles in bathrooms. No lights or fans etc allowed.
So your plan to add 2 bathroom receptacles will not be code since the circuit also feeds lights and fans. If you can move the lights and fans to another circuit you can add the receptacles. The lights and fans can be on any other circuit.
I didn’t get a chance to work on this last weekend.
After thinking about it more, should I put the (2) GFCI receptacles (1 in each bathroom) on its own circuit? If so, I will connect these to its own junction box in the attic so later an electrician can run a dedicated line to it.
So, what option would be best?
OPTION 1:
Junction Box 1 (later to be on its own circuit)
- Bath 1 - GFCI receptacle
- Bath 1 - Wall Light
- Bath 1 - Ceiling Vent
- Door Bell transformer
Junction Box 2 (later to be on its own circuit)
- Bath 2 - GFCI receptacle
- Bath 2 - Wall Light
- Bath 2 - Ceiling Vent
OPTION 2:
- Bath 1 & 2 - Wall Light
- Bath 1 & 2 - Ceiling Vent
- Doorbell Transformer
- Bath 1 & 2 - GFCI receptacle
1 doorbell
1 doorbell
You certainly may the only restictions apply to single outlets. That is to say a single device on a single yolk. A GFI receptacle is the same as a duplex receptacle.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
