Correct Fuse Sizes For Old Electric Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2010, 10:28 PM   #1
Rewards Points: 682
Correct fuse sizes for old electric panel?
I'm double checking on what an electrician told me. He recommended 20 amp buss fuse for socket circuits, and 15 amp buss fuse for lighting circuits. Is this correct?
darsunt is offline   Reply With Quote
Old 09-15-2010, 10:40 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it would depend on what size the circuit wire is. You can install a 20 amp fuse on nothing smaller than a #12 wire and a 15 amp fuse on nothing smaller than a #14 wire.
Old 09-15-2010, 10:55 PM   #3
" Euro " electrician
frenchelectrican's Avatar
All it depending on the conductor size if you have 2.5mm˛{#14 AWG} then you have to use 15 amp fuse while the 4.0mm˛{#12 AWG } it have to be 20 amp fuse size { yeah you can use smaller fuse on this one escpally with long run to prevent voltage drop issue }
Merci.
Marc
Old 09-16-2010, 05:21 AM   #4
Chicago, IL
Michael Thomas's Avatar
Once you determine the correct fuse size for each branch circuit, consider installing type "S" fuses with appropriately sized rejection bases:
- http://homerepair.about.com/od/elect...se_types_2.htm
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-16-2010, 06:31 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
As a blanket statement he is dangerously incorrect.
Old 09-16-2010, 07:38 AM   #6
Some fuse panels had buttons in the fuse holder(hot connector) with the fuse size stamped into them.
Old 09-16-2010, 07:58 AM   #7
steveel's Avatar
I'm not an electrician, but I think it is the smallest wire in the circuit that determines what you can do at the panel. I mean, just because you might have a 12g wire in the panel, maybe it's only a few feet long and is then connected to a smaller 14g wire for the rest of the circuit. DIYers did silly stuff back in the day too, not just now. If you don't know what size to screw in, a licensed electrician should inspect the entire circuit to figure that out. Overloaded wires are one of the major causes of fires, so don't GUESS and don't ASSUME everything downstream of the panel meets code. Here's one time to pay the pro.
steveel is offline   Reply With Quote
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 10:01 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
First time with old style fuses in fuse panel darsunt Electrical 3 06-20-2007 04:53 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
