Is This Correct And In Compliance With NEC? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 05:52 AM   #1
Is this correct and in compliance with NEC?
Hi all,
I'm new and looking for advice on something I want to do. Sorry for the long post but I'll try to explain it clearly.
I have now:
  • Main panel, 200A service on meter
  • Sub panel, 100A service
  • Generator panel for feeding some circuits
  • Separate off peak meter presently not used
The off peak meter goes to a single 220V 30amp breaker in its own box. It used to feed the water heater but was disconnected when the generator panel was installed. Now, the water heater is fed by the generator panel which is fed by the 100A feed from the main panel to the sub panel. The generator panel has an 'either or' (I don't know the correct term) main switch to feed it from either the generator or the 100A feed from the main panel.
I want to hook my dryer and water heater up to the off-peak meter.
I was planning to accomplish this by doing the following:
  • Change the breaker in the off-peak meter box from the existing 220V 30A to a 220V 70A (the box is rated for up to 70A)
  • Install a sub-panel that is fed from the off-peak meter box with #8 wire, the distance will be under 2 feet
  • Install 2 220V 30A breakers in the new sub-panel, one to feed the dryer and one to feed the water heater
  • Install an 'either or' switch at the water heater that allows me to feed the water heater from either my new sub-panel or my generator panel. The switch would have to be a break before make switch.
So, my questions are:
  • Is this to code?
  • What's the 'either or' switch I described called?
  • Do you have any suggestions for my installation?
Thanks in advance,
Steve
siearly is offline   Reply With Quote
Old 11-17-2009, 07:57 AM   #2
joed's Avatar
Rewards Points: 12,892
You may not be able to simply change the breaker to 70 amp. It depends on the size of the wires feeding the panel.
Old 11-17-2009, 08:11 AM   #3
Good point. The feed from the off-peak meter to the panel is 10 feet long and has the following markings:
XHHW CDRS 3000 VOLTS TO GROUND 2 CDRS 2 AL 1 CDR 4 AL
Physically, it contains two jacketed hot wires and one unjacketed twisted strand ground. All are aluminum.
Will this wire support a 70 main? If not what maximum load will it support?
Thanks,
Steve
Old 11-17-2009, 09:15 AM   #4
You say the off-meter is currently not in use ? Turned off ?
Usually these are for very specific uses
Pretty sure the water heater qualifies, I'm not sure on the dryer
Have you contected the POCO to run the change by them ?
Old 11-17-2009, 10:13 AM   #5
Not in use but not turned off. I've verified with the POCO and put a meter to it. They say I can connect anything I want to to it, as long as I'm okay with those devices being 'blacked out' during peak periods. For the HWH and dryer, I'm fine with that.
IS it correct? allawi Building & Construction 3 11-09-2009 06:49 AM
Correct oil level in Bristol compressor Aptguy HVAC 5 08-26-2009 09:56 AM
How do I pick the correct coaxial cable? fwmcbigfoot Home Theater 1 12-30-2008 09:45 AM
My roof is sagging - Correct Course of Correct Repair? young-jennifer Building & Construction 5 12-15-2008 07:59 PM
