Correct Cable For 10/2 In NM Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 08:20 AM   #16
Did I miss something? I tbought it was decided that you could pull uf thru your conduit as a chase without needing to strip or use boxes...
Evstarr is offline   Reply With Quote
Old 05-10-2012, 08:24 AM   #17
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Missouri Bound View Post
missed the part where you already ran the 2 1/2"
Oops! Me too.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 05-10-2012, 08:24 AM   #18
Licensed Pro
If you run the individual conductors in the conduit, you will only need one #10 ground... and be sure to keep the neutrals (white) matched to the appropriate hot.
Old 05-10-2012, 11:12 AM   #19
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Is there any way you can get the conduit so it goes into the living space or transfer over to SER cable to get inside so you could install a panel in an accesible location.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Tags
conduit
12/2 NM cable in 1/2" EMT conduit amakarevic Electrical 8 11-16-2011 02:42 PM
Running cable in conduit Audiotekm Electrical 10 11-09-2011 10:46 PM
Conduit for cable and phone brjl Electrical 6 04-05-2011 07:51 AM
MC cable through conduit StudebakerHawk Electrical 3 03-05-2010 10:38 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
