Correct 110v Ga Wire To Camper - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Jim Port
Old 01-23-2017, 05:40 PM   #1
Rewards Points: 4
Correct 110v ga wire to camper
Reposting,, I'm new and posted original post on wrong thread.
Currently running 350' of 12 gauge extension cords to camper. Most everything is 12v but we do run the microwave and coffee pot occasionally. I know we're pushing the load on the wire and plan to do one of two options. Go with 10ga (aluminum) underground to trailer or maybe move to a better site but that pushes the length out to 450'. Will the 10ga be enough for either application?
GaryGP is offline   Reply With Quote
Old 01-23-2017, 06:41 PM   #2
Licensed electrician
Rewards Points: 1,780
Re: Correct 110v ga wire to camper
You will not find aluminum conductors that small. Also a #10 aluminum would only be good for 20 amps.
Using the Southwire voltage drop calculator you would need #2 copper for a distance of 400 foot to keep voltage drop under 3%.
Yorkranger84 likes this.
Old 01-23-2017, 09:14 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
At that distance, solar may be a decent option as long as you don't use the microwave and coffee pot very often.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Correct NEC wire size calculations? HowMuch001 Electrical 36 04-05-2014 07:48 PM
Correct to HOT/NEU Reverse in camper. jpaytoncfd Electrical 6 07-20-2012 12:16 AM
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
roughing wire for 110V smoke detectors amakarevic Electrical 13 02-10-2009 10:11 PM
