Core Lighting Controls #OS306U Auto Sensor Light - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 12:57 PM   #1
Casper40's Avatar
Core Lighting Controls #OS306U Auto sensor light
I'm kind of new to this electrical stuff but anyway, here is my problem....
I've bought a Core Lighting Controls #OS306U Auto sensor light. I switched the power off at the breaker box, then unhooked the old light switch and hooked up the Core Lighting Controls #OS306U Auto sensor light. Flipped the breaker back on and the light in the bedroom was on! Great right!?? Well problem is I can't turn the light off.
Any ideas?
Casper40 is offline   Reply With Quote
Old 04-13-2013, 01:01 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You didn't connect the new light fixture the same as the old one was connected.
Old 04-13-2013, 02:30 PM   #3
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
I'll bet he pulled out all the wires and took them apart.
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 04-13-2013, 06:39 PM   #4
Casper40's Avatar
As I said I am new to this and not sure what I'm doing. What I did was turn of power to the switch, took the old one off, which had 3 black wires, I'm guessing a hot wire, one coming from the light fixture and one going to the hallway. The new auto sensor switch has 4 wires 1-hot, 1-out to light fixture, 1-ground and 1- 3-way. Not using the three way.
Old 04-13-2013, 06:47 PM   #5
k_buz's Avatar
You mixed up which black wires went together. It seems like you have tied the hot and the switch leg together. If you investigate other receptacles or lights in the home, I bet you will find some that do not work.
The Following User Says Thank You to k_buz For This Useful Post:
Casper40 (04-13-2013)
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 01:35 PM
