Cordage SJOW (SJOOW) In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 03:36 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Cordage SJOW (SJOOW) in conduit
I participate in another forum (Ridgid Tools electrical forum) and we have had a discussion about using cordage SJOW in conduit. I feel it is not allowed in conduit by NEC( 2011) 400.7 (6), others disagree. What say you?
http://www.ridgidforum.com/forum/t38360/
Coastal South Carolina
Old 07-31-2011, 03:44 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Just what I need, another forum. Lol.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-31-2011, 04:43 PM   #3
Rewards Points: 6,652
I have never seen it in a conduit. Seen it term in a junction box, and from there, wired per local codes, whether bx, conduit, or romex, but never placed in a conduit, because that is not what the cable is used for, or designed for.
Old 07-31-2011, 06:41 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,902
Reading the thread on the other forum, you're both right. But you're more right. It is not permitted in raceways, except when otherwise permitted by the code - and connections to movable equipment are one of those exceptions. So, where the cable is used for a submersible pump, it may be run through conduit part of the way. Connections to wet-niche pool lights are another common example of this installation. It's even a plausible argument that the conduit in such an installation is a sleeve, not a raceway, because it's only terminated at one end. However, you can't use it as a substitute for other wiring methods.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
gregzoll (07-31-2011), rjniles (07-31-2011)
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
What conduit should I use? mulltron Electrical 6 07-12-2011 02:34 AM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 01:50 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
