Cord To My Heating Pad Got Ripped Out From Its Circuit Board..any Help? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2008, 01:11 PM   #1
cord to my heating pad got ripped out from its circuit board..any help?
the heating pad cord connects to a circuit board which sets the low medium or high heat, etc. the 2 wires( i assume its copper) connects to these two nodes that are soldered onto the circuit board. I was wondering if anyone can help me with a quick fix. A soldering iron is cheaper than a new heating pad plus i would learn something along the way. Is this the right forum? Or can someone point me in the right direction? here is a pic of what im talking about.
cord to my heating pad got ripped out from its circuit board..any help?-p6060542.jpg   cord to my heating pad got ripped out from its circuit board..any help?-p6060543.jpg   cord to my heating pad got ripped out from its circuit board..any help?-p6060544.jpg
flashme18 is offline   Reply With Quote
Old 07-09-2008, 03:05 PM   #2
Looks like the wires were crimped to the lugs, and lugs attached to the board using eyelets, which were secured using a punch type tool. Finally, the whole thing was soldered to make a good electrical connection.
I am willing to bet that the wires used in the cord will not solder easily, and that you must replace the lugs. You will need a crimping tool and a punch tool to attach the wires to the lugs, and the lugs to the PC board.
Since the lugs are attached to the PC board using a rivet-like eyelet, you may have some trouble getting the old ones out without damaging the board.
I have had to drill such eyelets out.
It is possible that the cost of a new heating pad is low enough that such an operation is not worth the trouble.
fw2007 is offline   Reply With Quote
Old 07-09-2008, 03:43 PM   #3
Registered User
Termite's Avatar
Although you could replace the lugs with some work, your replacement constitutes a modification of a UL listed (or similar agency) electrical product. Modifications or repairs can present a fire hazard, and are always discouraged. You might use a different solder than you should, for instance.
A new heating pad is less than $20. Given the nature of the use of the product, and its proximity to your body and bedding, I'd advocate replacement not repair.
Old 07-09-2008, 04:05 PM   #4
I strongly agree. Think of your safety (or that of a family member) first.
FW
Old 07-09-2008, 05:08 PM   #5
Thanks for the quick replies. After reading that, it look is a lot more complicated than I thought. The heating pad actually cost over $30. It was a really good one. But with all that extra work, and the hazards, I will just buy a new one!
Old 07-09-2008, 08:20 PM   #6
liscenced electrician
Rewards Points: 538
id try soldering it. It may not come out as strong as it used to be, but it should work
jimmy21 is offline   Reply With Quote
Old 07-09-2008, 08:47 PM   #7
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
If you never soldered before, your connection is going to be pretty ugly. Can you order a new controller?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-09-2008, 10:21 PM   #8
Registered User
Termite's Avatar
And if it doesn't, its not like it will cause a spark, fire, or shock....Wait.... Oh yeah, it will.
Old 07-09-2008, 11:28 PM   #9
Rewards Points: 538
well it obviously can get ripped out from the factory so hes probably better off just not buying one at all
Inducer fan assembly or inducer control circuit board failing realblonde94526 HVAC 3 05-12-2008 08:28 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
