Copper To Aluminum (again) - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 09:55 PM   #1
Copper to Aluminum (again)
Hi Guys,
This question is kind of a follow up to a question I had about installing a new oven. I know the CU/AL topic has been addressed on this site, but I need to know about CU/AL connections for larger wires. Basicaly, since I'm swaping my old 40amp breaker for a 30amp one, I will need to connect the old #6 AWG AL wire to #10 AWG copper. The guy at the electrical supply store gave me multi tap connectors to do this. The kind that look like this: http://images.grainger.com/B333_27/i...1YRJ2_AS01.JPG I know that I'll need to use a oxide inhibitor also. I just want to make sure this connection is "kosher" or if anyone advises something else.
Improvised is offline   Reply With Quote
Old 05-25-2011, 10:06 PM   #2
Licensed electrician
Rewards Points: 1,634
As long as those connectors are listed for use with AL and CU you should be fine. They are also prefilled with an inhibitor.
Old 05-25-2011, 11:07 PM   #3
Thanks, Jim. They say they are listed for use with both so I'll use them.
Splicing Aluminum to Copper Wire dc4nomore Electrical 28 05-08-2012 01:56 PM
How to Rewire aluminum to copper wall outlet. deepseathomas Electrical 1 10-20-2010 02:11 PM
Pool Panel: Aluminum vs. Copper bcobb Electrical 18 09-16-2010 01:00 PM
Copper vs. Aluminum frame velux skylights? spup345 Building & Construction 1 09-13-2010 02:09 PM
Converting Aluminum Wiring to Copper ... njchan Electrical 4 03-14-2010 07:11 PM
