Cooktop Wiring Install - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 07:42 PM   #1
cooktop wiring install
Hello, I am replacing my cooktop. My question is with the wiring. The wall jb has two balck wires and a bare ground in it. The new cooktop has a black read and green wires. The two black wires in the jb are both hot. Do I just connect the black to black, and red to black, and green to bare ground?
Thanks for the schooling in advance.
ewill333 is offline   Reply With Quote
Old 01-12-2012, 07:44 PM   #2
jproffer's Avatar
Rewards Points: 706
Assuming the voltages are 240 across black to black and 120 across either black to ground, which it sounds like they are. Then yes.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
ewill333 (01-12-2012)
Old 01-12-2012, 07:46 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes.....however you need to check the electrical requirements of the new cooktop to make sure your existing circuit breaker and wiring are the correct size.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-12-2012, 07:48 PM   #4
Jproffer, thanks for the help. You just made it easier to sleep tonight. Thanks for the fast reply as well.
Old 01-12-2012, 07:49 PM   #5
I will definitely do that as well stubbie. Thanks.
Old 01-12-2012, 07:50 PM   #6
jproffer's Avatar
Rewards Points: 706
+1 on this too.
Sorry...sometimes I assume people would have already done things....and I shouldn't assume anything. Thanks Stubbie
Tags
cooktop , two hot wires , wiring
Replacing kitchen cooktop. Devilsid Carpentry 7 09-07-2011 11:32 PM
how to install phone wiring? fromscratch Electrical 16 08-15-2011 09:24 PM
wiring electric cooktop 4 wires to 3 wires 1234mom Electrical 34 07-02-2011 06:12 AM
heat pump install wiring question fireman0175 Electrical 1 08-03-2009 12:12 AM
Wiring help three wire to two wire install israelsoto99 Electrical 1 06-28-2009 10:24 AM
