Cooktop Wiring Code - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2008, 02:26 PM   #1
Cooktop wiring code
Hello,
I have an under-the-counter refrigerator. Above it I want to install an electric cooktop. Does the code specify how much clearance must be between the appliances?
Thanks,
Eric
epudimott is offline   Reply With Quote
Old 07-19-2008, 07:49 PM   #2
Furd's Avatar
National Electrical Code, no. Local building code, maybe. Appliance manufacturer, yes.
Most refrigerators want at least an inch of clearance all around for air circulation. Most drop-in cook tops have some reference that will be in the installation instructions.
Furd is offline   Reply With Quote
Old 07-19-2008, 09:08 PM   #3
Master Electrician
JohnJ0906's Avatar
I agree with Furd. You need to check the manufacturers instructions for the particular models you want to use.
FWIW, I have never seen a cooktop and fridge installed this way - which doesn't mean you can't.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-20-2008, 12:01 AM   #4
Registered User
Termite's Avatar
As an inspector, when code doesn't drive any clearance requirements, I'd definately check the manufacturer's installation instructions to determine that minimum clearances have been met.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Wiring a 240v Delonghi cooktop cape45 Electrical 12 11-08-2007 03:38 PM
What's code for wiring distance from end of studs? Webguy64 Electrical 2 07-17-2007 06:58 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
'Underground Wiring And Code. michaeltz Electrical 16 12-05-2005 08:58 AM
