Old 11-20-2009, 11:26 AM   #1
Cooktop wiring
I am replacing an old Jenn-Air cooktop with a new GE cooktop. My supply is a three insulated wire receptacle(the Jenn-Air had a plug) with 240 volts. The GE cooktop is 240v with a conduit and two insulated wires and one UNINSULATED copper wire. Can I simply connect the two insulated wires with lugs and connect the copper wire to the white insulated supply wire? My house wiring is probably 50 years old by the way.
The G.E. booklet says the cooktop is not to be used with a plug. Does this apply to old wiring circuits as above also? Thanks
debubba is offline   Reply With Quote
Old 11-20-2009, 04:32 PM   #2
Remodeling Contractor
Cooktop wiring
do you have one main panel that feeds this circuit or does it come from a sub panel? And is the main breaker in the main panel or elsewhere? Does your stove top have the need for both 110 and 220V? like a light included somewhere.
Old 11-20-2009, 06:35 PM   #3
Cooktop wiring
Yes.
Get a 90 degree 1/2" flex connector for the "conduit" coming off the cooktop.
Get a blank cover plate (same size as the old recep opening, 1 gang or 2 gang) with a 1/2" hole in it. Install the flex connector onto the flex and the blank cover.
Turn off and TEST power
Remove the old receptacle and wirenut tightly the new cooktop wires to the old branch circuit wires.
Screw the blank cover to the box making sure that the screws don't go in too deeply and hit the wiring.
Doesn't matter. It's straight 240V. Many cooktops are.
220/221 is offline   Reply With Quote
Old 11-20-2009, 08:58 PM   #4
Cooktop wiring
Thanks for the great answer. The HVAC man at my work said I could have just rewired the plug to fit the new cooktop but I am reluctant to do that when my booklet said that the GE cooktop was not to be used with a plug. By the way, the only light on my new low-end cooktop is the burner on indicator light. Thanks again.
More On This Topic
Placing speakers further apart in a room gives a better stereo effect. If you end up placing your speakers more than 12 feet apart, you will probably have to add additional speaker wire to reach the receiver. However, most speakers only come with about 6... Read More »
Hi I'm Jason, shooting on behalf of Expert Village today. Next I'm going to show you the beads. These beads were already prepared before we started shooting. I'm going to show you where they came from. They came from a piece of cowax cable. No one will... Read More »
While jumper wires can be purchased pre-cut from electronic retailers, you may find yourself in a situation where you need to make one that is a specific length but can't find that length in the store. When this situation arises you can make your own... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. We are looking for R-Value. It's the same thing up here in our ceiling. Okay if the... Read More »
This word read ge. Ge. Ge means arm. Ge arm. If we say ge buo. Buo also means arm so ge buo is one word exactly for arm. But if we say ge buo cho it means elbow. Ge. Read More »
Wiring Cooktop and Under Counter Oven Preach_2 Electrical 18 03-19-2009 05:30 PM
Wiring a Jen-air cooktop gunnydon Electrical 4 12-19-2008 12:33 AM
wiring gauge for a jennair cooktop pugvader Electrical 12 12-09-2008 03:48 PM
Cooktop wiring code epudimott Electrical 3 07-20-2008 12:01 AM
Wiring a 240v Delonghi cooktop cape45 Electrical 12 11-08-2007 03:38 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
