Cook County Grounding Rules - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 04:17 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by McSweny1103 View Post
You mean the Jumper for the meter, right?
right. All you have to worry about is what is inside your house. If there is a pressure valve, you will need to jumper that though. Basically anything that can be easily taken out of line needs to be jumpered across.
The Following User Says Thank You to nap For This Useful Post:
McSweny1103 (06-14-2010)
Old 06-14-2010, 04:39 PM   #17
So now the million dollar question is where do I find an adequate jumper line?
McSweny1103 is offline   Reply With Quote
Old 06-14-2010, 04:44 PM   #18
Just call me Andrew
Rewards Points: 1,020
They sell it at lowe's or Home Depot by the foot (they cut it for you). I think you only need #8 bare copper (but it can be insulated if you want) for 100A. I'd size it for 200A in case you ever upgrade, which I believe requires #6 - but I'll let someone verify those wire sizes. They also sell the clamps I pictured above at Lowes/HD.
Andrew
secutanudu is offline   Reply With Quote
Old 06-14-2010, 04:58 PM   #19
nap
You talking to me?
nap's Avatar
water pipe bond and jumper is determined by the feeder size
up to #2 cu or 1/0 al requires #8 cu
1 or 1/0 cu or 2/0 - 3/0 al requires #6 cu
2/0-3/0 cu or 4/0- 250 mcm al requires #4 cu
McSweny1103 (06-15-2010)
Old 06-14-2010, 05:07 PM   #20
Just call me Andrew
Is that in the NEC somewhere?
Or should I say...
Where in the NEC is that?
Andrew
Old 06-14-2010, 05:22 PM   #21
nap
You talking to me?
nap's Avatar
Originally Posted by secutanudu View Post
is that in the nec somewhere?
Or should i say...
Where in the nec is that?
250.66
there are exceptions for a GEC to only a ground rod only has to be a max of #6 and a GEC to only a concrete encased electrode only has to be #4 (I think). There are no exceptions for the jumper and GEC to the water pipe that I am aware of.
The Following 2 Users Say Thank You to nap For This Useful Post:
McSweny1103 (06-15-2010), secutanudu (06-15-2010)
Old 06-15-2010, 11:59 AM   #22
Thanks for all the info. As I was reading all of this, it made me wonder. Do I have to ground the box to an external ground rod, or is the bonding, via the jumper sufficient?
It looks like there was a ground rod outside before, but it was not connected to anything, the wire and strapping that had bene connected was broken or gone, and the rod was pulled out (it was only 2 ft long) along with an ivy root.
Old 06-15-2010, 12:08 PM   #23
Just call me Andrew
If the water pipe that you are bonding to is metal (if not, what's the point), then that water pipe can be your ground rod. So if you have a metal supply line (metal from the street to where you hook up the jumper), i don't believe you also need a ground rod.
Andrew
The Following User Says Thank You to secutanudu For This Useful Post:
Old 06-15-2010, 12:25 PM   #24
Master Electrician
Rewards Points: 3,870
Most jurisdictions will require the ground rods as well as the metallic water pipe as the grounding electrode system.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 06-15-2010, 02:06 PM   #25
I believe I am going to double up the ground. Go one level heavier on the jumper cable then the NEC requires, as well as running the grounding rod.
Old 06-15-2010, 04:05 PM   #26
nap
You talking to me?
nap's Avatar
actually NEC specifically requires a supplemental ground rod be used if the only grounding electrode present is the water pipe.
Old 06-16-2010, 08:20 AM   #27
Chicago, IL
Michael Thomas's Avatar
McSweny1103
Take a look here:
http://ecmweb.com/grounding/electric..._vs_bonding_6/
___________
I'm paid to be suspicious...
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
McSweny1103 (06-16-2010)
Old 08-10-2010, 09:17 PM   #28
Ok, one last question i know this is old....
How do I know my feeder size?
Old 08-10-2010, 09:49 PM   #29
nap
You talking to me?
nap's Avatar
well, that can be difficult. The wire is required to be marked but it may not be visible on the small section you can see. Other than that, comparing your wire to a wire of a known size is about the only other way.
Old 08-11-2010, 08:38 AM   #30
So basically, just used the #4 copper.
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Stabing back of receptacles in cook county IL Redrock Electrical 17 09-21-2009 04:50 PM
Sub Panel Grounding bar bmancanfly Electrical 12 05-24-2009 02:07 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
