Old 04-29-2012, 06:36 PM   #1
Converting wall switch to outlet to switch ceiling fixture
I have 3 bedrooms on 15 amp circuits, 14 gauge wire. Original wiring is one bedroom is on one circuit and the other 2 bedrooms on another circuit. The wall switches in each switched the top half of an outlet in each room. I converted the wire at the wall switch to a 110V feed from the outlet and ran 14/3 from the switch to the ceiling for a ceiling fan. I replaced the outlets since the jumper was cut to isolate the 2 plug ins for switching. Is this whole scenario code compliant?
elmaur is offline   Reply With Quote
Old 04-29-2012, 06:48 PM   #2
A "Handy Husband"
rjniles's Avatar
Sounds fine- make sure you use fan rated boxes at the fan location.
Coastal South Carolina
Old 04-29-2012, 07:10 PM   #3
Yep, I got the boxes that have the bar that expands to anchor itself between two beams.
I was just made aware that new wiring for lighting has to be separate from outlets. That would make this wiring scheme not right. Anybody have info on this?
Old 04-29-2012, 07:16 PM   #4
A "Handy Husband"
rjniles's Avatar
Not true. Receptacles and lighting (in bedrooms) can be on the same circuit. There are limitations on some circuits (like kitchens) but you are fine with bedrooms.
Old 04-29-2012, 07:23 PM   #5
I do hope this is true. I will be getting a permit and inspection for the garage subpanel and other electrical upgrades. They might scrutinize everything.
Old 04-29-2012, 07:27 PM   #6
joed's Avatar
You are fine. What you did is a very common change and meets all codes.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-29-2012, 08:28 PM   #7
Okay, thanks.
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 09:13 AM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 07:11 PM
