Old 01-31-2013, 04:04 PM   #1
DIYAddict
hummin40's Avatar
Send a message via Yahoo to hummin40
Converting a wall fixure
Help! I have a project I'm hoping someone can talk me through. I am attaching a photo of the 'look' I am trying to achieve and the help I need. I have a wall light fixture that I would like to replace with a chandelier like the picture shown. Also, the mirror is too tall to use if I don't change out the fixture so regardless, the light will need to be changed out somehow.
How will I convert the electrical outlet so that I can wire a light, either ceiling or higher than existing fixture? My guess is I will need to direct-wire a light.?.
The ceiling above the bathroom is our bedroom floor upstairs. The existing light is on an exterior wall. I just don't know how to make a wall electrical outlet accessible for a hanging light.
Any help would be greatly appreciated!!
Well it only let me post 1 of 3 pictures
hummin40 is offline   Reply With Quote
Old 01-31-2013, 04:25 PM   #2
A chandelier would hang from the ceiling.
Really need a picture of what you have now.
Old 01-31-2013, 06:15 PM   #3
DIYAddict
hummin40's Avatar
The picture attached is what I have now. I want this light fixture removed and a chandelier instead. I wish this would let me post more than one picture.
Thanks!
Old 01-31-2013, 07:05 PM   #4
Licensed electrician
Hanging fixtures are not allowed within 3' horizontally of a tub or shower footprint.
Old 01-31-2013, 09:52 PM   #5
MCB
sparky
Lots of room to move it up to accommodate the mirror. Should be some extra wire in behind the wall, but even if not, you should be able to move the whole box upwards and patch the hole where it was.
Mark where the top of the mirror will be, turn the power off, remove the fixture and move the box it was fastened to, up.
Nobody wants a plug in lamp in the bathroom.
MCB is offline   Reply With Quote
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Can I remove this wall..? (Image) findlay70 Building & Construction 8 04-27-2011 06:02 PM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 09:43 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
