Converting A Single Pole Switch To A 3 Way - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2006, 12:23 PM   #1
Rze
Average Joe
Rewards Points: 79
Converting a single pole switch to a 3 way
I have a situation where there is a single pole switch at the top of a flight of stairs. You have to Climb the stairs to turn on the lights. I need to install a switch at the bottom of the stairs so the light can be operated from both the top and bottom.
3 - way switches are my mental block
Currently, the line goes from the switch to the fixture
I assume I need to install a new 3 way switch, replace the single pole with a 3 way, and then run a 3 wire between the two switches. This is where I get stuck.
Not sure how to wire the Line in to the first switch.
Any help would be appreciated.
Rze is offline   Reply With Quote
Old 11-16-2006, 01:28 PM   #2
They're all fixer-uppers
J187's Avatar
WHere I live, its a code violation to have stairs with only one switch point. Anyway, save me from describing 2 completely different diagrams - where does the power come in, at the switch or at the fixture?
J187 is offline   Reply With Quote
Old 11-16-2006, 04:28 PM   #3
Rze
Average Joe
Rewards Points: 79
I would think it's a violation here also...this is amuch older buidling used for community theatre.
I probably wasn't clear. Line in (Power) to the switch , then to the fixture.
Old 11-16-2006, 05:24 PM   #4
joed's Avatar
Rewards Points: 11,534
This is simpel once you get the wire to the new switch.
I am gong to skip ground wires nthe description. Connect all of them together and to the switch if it has a ground screw.
Remove the two wires from the existing switch. Leave everything else alone.
Connect one wire to the common screw of your new threeway switch.
Connect the other one tothe black wire to yur new switch.
Connect the red and white wires to the remaining two traveler screws of the new switch.
At new switch connect the black to the common screw.
It will be like this.
Old 11-18-2006, 09:37 AM   #5
Rze
Average Joe
Rewards Points: 79
THANKS! A picture is worth a thousand words. Howvere I like to understand the WHY instead of just following teh picture. This is a great help.
Dave
Old 05-01-2011, 02:11 PM   #6
2 way to 3 way
The pictures are not showing up for me, and I wondered if you can post a picture also with the condition that the power is coming into the light and then to the switch(es)? Thank you so much! Terri
tkrause is offline   Reply With Quote
Old 05-01-2011, 03:30 PM   #7
joed's Avatar
It makes no difference where the poewr comes in. There are two wires on the existing switch Those are the ONLY two wires you need to deal with.
In this image assume the black and white wire entering the switch are the two wires attached to the switch. Remove them from the switch and connect as the diagram. Do not alter any other wires in the switch box.
Old 05-01-2011, 04:34 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If they make the NEC change requiring a neutral in every switch box, that will make this project difficult.
Especially if there is no neutral in the original switch box.
Coastal South Carolina
Old 05-02-2011, 07:58 AM   #9
Thank you
Thanks so much to both of you for your time and assistance!
Old 05-02-2011, 11:10 AM   #10
Sparky
Rewards Points: 510
That's already in the 2011 NEC...
Techy is offline   Reply With Quote
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-24-2009 12:06 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
installing a single pole switch yummy mummy Electrical 18 04-27-2007 08:06 PM
