Converting Single Phase To Three Phase - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 04:28 PM   #1
ogoa's Avatar
Converting single phase to three phase
The machine I want to purchse requires a three phase and 230 volts.
I am not sure whether I have single phase or a three phase and amount of voltage. If it happens to be a single phase, are there any solutions to making it a three phase with 230+ voltage to run my machine?
I looked into some convertors and what not, but you guys would know more than me... any convertors that would work, or other solutions?
thanks!
ogoa is offline   Reply With Quote
Old 02-05-2012, 04:45 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If it's three phase you will have three hots and one neutral four wires going into your panel. If this is at a home it's most likely a single phase.
Another thing you will have to check how many amps available and how many amps the machine takes.
rrolleston is offline   Reply With Quote
Old 02-05-2012, 04:56 PM   #3
Idiot Emeritus
Rewards Points: 1,492
It depends on the type of machine. Some are more picky about their power than others.
If it's motors only and none are loaded to 100% a rotary phase converter would very likely work. You need to be careful of the control circuit here, don't connect it to the manufactured phase.
If it's one or more motors that all run at the same time, and the total load is less than 5HP, a VFD would be a good choice. Motors run on a VFD can operate at very close to 100% of their capacity. Again, the control circuit cannot be connected to the load side of the VFD.
A static phase converter will run a 3 motor at about 60% of its capacity.
micromind is offline   Reply With Quote
Old 02-05-2012, 05:00 PM   #4
MarginallyQualified
Rewards Points: 2,464
I looked into some convertors and what not, but...
You don't want a "converter". You want a "transformer".
Plain vanilla everyday item. Not so cheap but still plenty common.
As to the specific size/rating etc...
Contact the tool or machine company for what solution they have used before.
Old 02-05-2012, 05:13 PM   #5
Rewards Points: 3,256
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
plummen (02-05-2012)
Old 02-05-2012, 05:46 PM   #6
Idiot Emeritus
A transformer cannot make 3 from single phase.
The most common ways to get 3 power from a single phase source are;
1) Static phase converter. This is the least costly, but also has the most drawbacks.
2) Rotary phase converter.
3) VFD that will accept or is designed for single phase input.
I don't know of any others.
Rob
The Following 3 Users Say Thank You to micromind For This Useful Post:
frenchelectrican (02-05-2012), mpoulton (02-05-2012), plummen (02-05-2012)
Old 02-05-2012, 05:46 PM   #7
Rewards Points: 506
Originally Posted by zappa
Second that.
jlmran is offline   Reply With Quote
Old 02-05-2012, 06:19 PM   #8
Rewards Points: 13,960
http://www.phaseconverter.com/
Old 02-05-2012, 07:27 PM   #9
dmxtothemax's Avatar
Rewards Points: 5,492
A rotary convertor is an option,
So to is an electronic based invertor,
depending on currant capacity needed !
dmxtothemax is offline   Reply With Quote
Old 02-05-2012, 08:20 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,970
Post all of the technical information about the machine and we could probably give better advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 02-05-2012, 08:34 PM   #11
Missouri Bound's Avatar
Depending on the size of the machine motor, it may be cheaper to change out the motor. What's the HP rating of the machine?
Do you want it your way or the right way?
Old 02-05-2012, 09:04 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Uh yeah,last time I looked a transformer was for stepping voltage up or down.
Hang on let me look on my pole out back...............,yep thats still what it does!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 09:33 PM   #13
I dont think a tranny would work !
Whilst a tranny could step up the voltage !
And you could get three secondary windings !
What you wont get is the phase seperation that
three phase motors need !
I.E. 120 degree's difference between phases.
Old 02-05-2012, 09:36 PM   #14
plummen's Avatar
Exactly,2 totally differant creatures alltogether
Converting 3 phase equipment to single phase /VFD? lightison Electrical 7 01-04-2011 03:14 PM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 09:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-23-2009 11:06 PM
