Old 03-15-2009, 08:33 PM   #1
Converting plug-in pendant lamp to wired from electrical box. Need Help!
Hi,
I bought a pendant lamp that is originally a plug-in. I'd like to install the lamp on the electrical box that is already in the room. I know that the ribbed cable would be the one to hook up to the white cable in the box, and the other to the black.
My question is - what do I do about grounding the lamp? Being that it is originally a plug-in lamp, it does not have a ground wire to attach to the box. I'm not an electrician, but I've installed many light fixtures - none of which were converted. I'm confident with everything else, but I'm not sure whether installing without a ground wire is a good idea.
Thanks in advance
tioleo is offline   Reply With Quote
Old 03-15-2009, 08:41 PM   #2
If it came from the factory without a ground, don't worry about it.
Ikea??
220/221 is offline   Reply With Quote
Tags
converted lamp, ground wire, grounding, pendant lamp
Using a european lamp in the States mattlima Electrical 3 03-16-2008 09:12 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 01:34 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
