Converting Gas Stove To An Electric Stove? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 08:33 PM   #1
Converting Gas Stove to an Electric Stove?
I'm have been using propane gas for hot water heater and stove up until now, but I'm changing to an electric hot water heater, and don't really have the money to purchase a new stove right now. Can anyone tell me how expensive and complicated it it might be to convert a gas stove to electric??? I have to make a decision asap, so any help with this would be Great!
LooptieLu is offline   Reply With Quote
Old 01-06-2011, 08:36 PM   #2
Master Electrician
Rewards Points: 3,820
This is a joke, right?
brric is online now   Reply With Quote
Old 01-06-2011, 08:36 PM   #3
Experienced
Jackofall1's Avatar
How far is it from the breaker panel to the stove location?
Basement? Crawlspace? Access to run wire?
Available space in main panel?
Old 01-06-2011, 08:39 PM   #4
Where are you located ?
The Following User Says Thank You to Scuba_Dave For This Useful Post:
LooptieLu (01-07-2011)
Old 01-06-2011, 08:40 PM   #5
Rewards Points: 6,652
$300 for a new stove, another $300 or so for Electric work, so rough guess $6-700.
Old 01-06-2011, 08:43 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Old 01-07-2011, 06:45 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,... My guess is, it would cost about 3 times the price of a new electric stove....
The Following User Says Thank You to Bondo For This Useful Post:
Old 01-07-2011, 08:32 AM   #8
Rewards Points: 256
And it would cost 10-20 times more than the cost of a used electric stove.
In all seriousness, you can get a used electric stove for $50 around here, free if your patient and can deal with avacado green.
The expense will be the wire, if your stove is close to your breaker box and you have two open slots your in luck.
Still expect to spend 50-100 in electrical supplies.
If your looking for a cheap workaround get an electric griddle and an oversized toaster oven. Both those run off a standard outlet.
michaelcherr is offline   Reply With Quote
The Following User Says Thank You to michaelcherr For This Useful Post:
Old 01-07-2011, 10:20 AM   #9
Thumbs up
No,jbfan, NOT a joke , though I wish it was!
Thanks so much! Not exactly what I wanted to hear, but kind of expected as much. Needed some direction with this, and REALLY appreciate the advice!
Scuba_Dave, I'm located in Alabama.
Tags
electric , gas conversion , stove
Converting electric stove to gas - HOW? styler1010 Electrical 10 05-31-2010 01:22 AM
Converting Electric to Gas stove LaurynJohnny Appliances 16 03-26-2010 08:08 PM
Electric Boiler Merged w/ Wood Stove Radiator westphaltyler HVAC 1 03-23-2009 10:44 PM
Converting from Gas to Electric Stove Chloe Appliances 1 06-14-2008 03:06 PM
Electric Stove Help tempmeo Electrical 7 06-05-2006 07:18 PM
