Converting Gas Range With Pilot Lights To Electric Start Gas Range - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 10:36 AM   #1
Converting Gas Range with pilot lights to electric start gas range
I have just purchased a home with an Imperial Gas Range with 9 pilot lights that burn continuously. I am not comfortable with this due to the smell of gas and just general safety issues. I would like to see if there is a way to convert the range to some sort of electric start burners so i can get away from having the pilot lights burning. Any suggestions?
waterhead is offline   Reply With Quote
Old 01-02-2010, 10:56 AM   #2
Rewards Points: 160
I am not an appliance man, but this seems pretty straight forward. Buy a new range. Then have an electrician install a receptacle or connect the range for you. Once you get the range or find one you like, see what the electrical requirements are in advance.
Old 01-02-2010, 11:06 AM   #3
Licensed electrician
Rewards Points: 1,608
i would say the best way would be to purchase a new gas stove.
There is probably no need to change anything electrically.
Old 01-02-2010, 11:41 AM   #4
Rewards Points: 177
You should not smell any gas with pilot lights. If you are, then you are having a problem. There also is no safty issues with a standing pilot. They are probably safer since with a pilotless stove the gas can can be turned on and have gas leak without the burner lighting.
paul100 is offline   Reply With Quote
Old 01-02-2010, 01:14 PM   #5
joed's Avatar
Rewards Points: 12,852
Plus they work if the power is out.
Old 01-02-2010, 07:16 PM   #6
Buy a new gas range if you want electronic ignition burners.
BTW, you should only smell gas during the short time ater you turn a burner on and before the pilot light causes it to light. Any other time, you shouldn't smell anything.
Willis
williswires is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
pilot lights, but not burners DangerMouse HVAC 34 09-14-2008 07:19 AM
comfortmaker pilot lights but not burner jasonzzz HVAC 6 01-28-2008 11:20 AM
lights brighten or dim at motor start geeyathink Electrical 4 07-07-2006 09:06 PM
