Converting From Gas To Electric For Stove - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 12:39 PM   #1
Converting from gas to electric for stove
I'm having my electrician put my kitchen outlets on a different circuit because my inspector said I'll continue to blow a fuse. HUD home, total rehab, long story short, everyone agreed.
While I'm having him do that I was thinking of converting from gas to electric for oven... If I stay with gas, I have a flex pipe coming up from the basement that the gas company said I have to switch as well...what are the consequences if I don't and how will they ever know are beyond me.
Would it make sense to convert to electric while my electirican is there?
whiteryno is offline   Reply With Quote
Old 06-03-2011, 02:25 PM   #2
Just call me Andrew
Rewards Points: 1,020
I don't think you want that flex pipe running up from the basement. They won't know until they see your house on fire.
If you want an electric oven, it'd make sense to convert. Or have that flex pipe replaced with rigid pipe.
Andrew
secutanudu is offline   Reply With Quote
Old 06-03-2011, 03:01 PM   #3
Rewards Points: 160
I converted from gas to electric about 8 years ago. How far from your circuit panel to the stove? You'll need to run 6/3 wire which is not cheap! My run cost about $300 just for wire and copper was a lot cheaper back then.
Most likely cheaper to fix the pipe unless you really prefer an electric stove.
cgoll is offline   Reply With Quote
Old 06-03-2011, 03:17 PM   #4
Yeah don't really care about an electric oven. Just not sure if fixing that flex pipe is a big issue or not.
Old 06-03-2011, 03:21 PM   #5
And whats the problem with the flex pipe running up from the basement anyway
Old 06-03-2011, 04:33 PM   #6
I=E/R
a7ecorsair's Avatar
When you say flexible pipe are you referring to what is call CSS - Corrugated Stainless Steel or just copper tubing?
a7ecorsair is offline   Reply With Quote
Old 06-03-2011, 04:40 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
He probably talking about the corrugated steel or brass gas appliance connector. They are not approved for through the floor or wall use. You are also supposed to have a gas cock (shutoff valve) in the same room as the appliance.
Fixing it involves installing threaded black pipe from below the floor into the location of the appliance and installing a gas cock.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-03-2011, 04:47 PM   #8
I=E/R
a7ecorsair's Avatar
Interesting The heating company that did the gas work on my new house ran CSS from the crawl space into the kitchen for the LP gas stove. The shut off is at the manifold in the crawl space.
Old 06-03-2011, 06:22 PM   #9
A "Handy Husband"
rjniles's Avatar
CSS is OK for that use but the gas cock must be in the same room as the appliance. CSS and the corrugated appliance connector of which I spoke are different animals.
Converting Gas Stove to an Electric Stove? LooptieLu Electrical 8 01-07-2011 10:20 AM
Converting electric stove to gas - HOW? styler1010 Electrical 10 05-31-2010 01:22 AM
Converting Electric to Gas stove LaurynJohnny Appliances 16 03-26-2010 08:08 PM
Converting duplex to single family--what to do with electric services? zamoti Electrical 32 01-29-2009 03:16 PM
Converting from Gas to Electric Stove Chloe Appliances 1 06-14-2008 03:06 PM
