Converting Electric Stove To Gas - HOW? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 10:40 AM   #1
Question
Converting electric stove to gas - HOW?
I live in a 70's condo that has an electric stove. How do I go about converting it to gas? Do I first contact the gas company? or get the stove people to do that? We have gas in the attic for water heater and a nearby fireplace that is in an adjoining room.
styler1010 is offline   Reply With Quote
Old 05-29-2010, 10:52 AM   #2
Mad Scientist
I'm afraid that's a job for the appliance store; you'll need a new stove. I've never seen an electric stove that can be converted to gas, or vice versa.
McSteve is offline   Reply With Quote
Old 05-29-2010, 10:53 AM   #3
Remodeling Contractor
I assume you mean to replace the stove with a gas unit. A plumber would be the one to call. The gas company would not necessarily be involved since you say you already have gas service. Be sure you have natural gas or propane so you get the correct stove to match.
Old 05-29-2010, 10:58 AM   #4
the Musigician
DangerMouse's Avatar
I'd add that if you look behind the electric stove, you may see there is already a gas valve there waiting for you!
If not, you will have to add a gasline run to the area and have it inspected, etc. In addition, you say you live in a condo, so there may be more to it than simply that in the way of permits, committee approval, etc.
DM
Old 05-29-2010, 12:56 PM   #5
Converting Electricty to Gas as Stove's Power Source
Man! You guys are specific on here - I'm just an English major. Thanks for all the info. I am confused, however, by why one would need a plumber as one post indicated somewhere back in 2007.
Naturally, you can't call the gas company to ask these questions on a Saturday when you may have time to contemplate them.
Do you have any idea how much it would cost to run a natural gas line from the attic to the kitchen (approx 10 ft.) or same distance room to room from fireplace to far wall of kitchen/great room combo?
I hear you regarding checking w/condo board, but some of the residents must have gas conversions so it looks probable that they would approve.
Old 05-29-2010, 06:46 PM   #6
DIY staff
Rewards Points: 7,174
The cost of dropping a gas line into the wall is not something that we could tell you.
Plumbers hourly rates vary by state and town. The ease or difficulty can not be known with out seeing the job.----Mike-----
Old 05-29-2010, 06:50 PM   #7
Gas Co runs gas to the residence
Plumber runs gas lines in the residence
Prices vary by location & specific job
Old 05-29-2010, 11:55 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Styler.,
The best bet if there is no gaz pipe for the stove call the plummer { there are qualifed crews that can work on gaz pipes and some HVAC contractors will do it as well so check it out as well }
As far for the cost that something I don't able tell you the prices due too many variations it will be involded.
Oh yeah the instering part with gaz stove if you have range hood make sure they are direct vent not in recircuation mode at all { quite few states have this codes related but I am not suprised that Canada should be about the same rules as I mention above }
Merci,Marc
Old 05-30-2010, 07:11 PM   #9
joed's Avatar
Rewards Points: 13,292
Don't forget the electrician for the new 120 volt receptacle or get one of these.
Woods stove adaptor
Old 05-31-2010, 12:44 AM   #10
Mad Scientist
Woods stove adaptor
That's a handy gadget. I thought you'd still need to change the breaker out for a 15-Amp, but I see that that adapter has a 15 amp fuse in it. Sweet.
Old 05-31-2010, 01:22 AM   #11
That is the coolest thing I have see it for while I should buy couple of that.
Merci,Marc
Tags
electric stove , gas conversion
Converting Electric to Gas stove LaurynJohnny Appliances 16 03-26-2010 08:08 PM
re-wiring an old electric stove user62257 Electrical 3 09-15-2009 11:44 AM
Electric Boiler Merged w/ Wood Stove Radiator westphaltyler HVAC 1 03-23-2009 10:44 PM
Converting from Gas to Electric Stove Chloe Appliances 1 06-14-2008 03:06 PM
Electric Stove Help tempmeo Electrical 7 06-05-2006 07:18 PM
