Converting Duplex To Single Family--what To Do With Electric Services? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 08:18 PM   #16
Too late to consider ever going back now. The water main has already been cut down from two to one, telephone and cable have been unified with the secondary systems having been removed from the pole back. Major structural elements in the basement have been modified to allow access to both sides of the house. Once the kitchen is moved, there will be a single gas service. Electrical is the last to go (if it ever goes).
This property is worth almost twice it's original value as a single family as opposed to a duplex. As a duplex the fair market value was limited by the [potential] rent. As this is a bit of a "snooty" neighborhood that has a number of low rent neighborhoods within a 15 min drive, rents are kept low even though home prices remain relatively high compared to neighboring communities.
In short, unless the next owner of this home likes throwing away their money, it will likely remain single family unless the dynamic of the neighborhood changes significantly. By then, I'll probably be living elsewhere!
zamoti is offline   Reply With Quote
Old 01-20-2009, 09:24 PM   #17
DIYer
I second the idea that you should think twice about full house electric tankless. Consumer reports refused to even review them on the grounds that they are not even close to performing acceptable for most users, and the energy benefits are nearly nothing.
Gigs is offline   Reply With Quote
Old 01-21-2009, 09:13 AM   #18
It would seem that the general consensus is that the electric tankless water heater is a big fat failure. HOWEVER, I'm really curious to know on what facts is this judgment based?
I'm doing my best to seek high-value investments for my home and tankless hot water seems promising, but I'm finding it difficult to find honest, unbiased, fact-based information out there. Does anyone have any solid evidence for or against these things? It seems that the original question about the electrical system has been answered, for which I am grateful, but now the conversation has moved into the actual/perceived cost savings of tankless hot water; in my case electric as installing a gas-fired system is not a cost-effective option for me (in terms of installation).
So what's the deal? Anyone with one of these things installed in their home out there care to weigh in?
Thanks again for all of the responses!
Old 01-21-2009, 09:51 AM   #19
Ok, got off my lazy arse and just called a manufacturer. I spoke with a fellow at Stiebel-Eltron as they seem to make one of the better devices and here is what he told me regarding cost of use.
At my incoming cold water temperature which is 45 F during a cold week in Pennsylvania, with $0.14 per kwh he stated that it would cost about $150 a month to run this unit one hour solid at maximum usage (4 GPM @ 125). In summer, perhaps a little less as the incoming cold water temperature will rise a little.
So there, we have some actual numbers for usage.
FYI, I'm not trying to sell anyone on this particular device, I'm just trying to contribute solid information to the conversation. Anyone got a comparable gas calculation out there? Gas tank vs. gas tankless?
Old 01-21-2009, 04:10 PM   #20
DIYer
zamoti, yes, consumer reports compared gas tankless and gas tanked. They found that the tankless are not worth it, it would take 20+ years to recoup your investment because the energy savings are nearly zero. And once you factor in yearly professional service to clean out scale and to maintain it, it may never be worth it.
http://www.consumerreports.org/cro/a...heaters-ov.htm
This is the same article where they talk about how electric tankless are such a joke they won't even review them.
Old 01-22-2009, 11:36 AM   #21
Gigs,
Thanks for the link, but this isn't really pertinent. They test a gas tankless to a gas tank. They rule out electric because of the high amperage requirement that I have at my disposal. Saying that they called electric tankless a "joke" and wouldn't test them is a bit misleading as this is what they really said:
"We didn't test electric tankless heaters because many can't deliver hot water fast enough to replace a conventional water heater if ground*water is cold. Even in areas with warm groundwater, most homeowners would need to upgrade their electrical service to power a whole-house tankless model."
Now that said, it could be the case that my 45 water may be a bit on the cold side to heat, but I've nothing to go on but the manufacturer's word that a given unit would bring 45 water up to 125 at 4GPM. This is why I'm soliciting advice based on solid evidence--I can't find much to prove or disprove the manufacturer's claims.
Anyone out there have any real-world experience or evidence thereof?
Thanks again everyone
Old 01-22-2009, 11:55 AM   #22
Rewards Points: 150
Consider this, where you live, who would you call to fix your instant hot water heater?
harleysilo is offline   Reply With Quote
Old 01-22-2009, 12:20 PM   #23
Learning by Doing
Leah Frances's Avatar
My bottom line: for me at the end of day of DIYing, a long hot shower is a luxury I do not want to live without. Honestly evaluate how you, and your family, use hot water and how you want to use it. Then make your choice.
Last easter our water heater failed (dumped 40g HOH and around 6g Fuel Oil ).
I was inclined to replace with tankless until I started mapping my plumbing system. There is a significant distance between our kitchen sink and master bath (70+ pipe feet). Both electric and gas on-demand manufacturers recommended to us that we install TWO on-demand systems: one for the kitchen/laundry, and one for the bathrooms.
Otherwise, we would sacrifice "Comfort" (their words - I interpreted to mean: if someone's in the shower don't do laundry/dishes/run dishwasher or both will get luke-warm water). Two systems and two installs began to get unreasonable $-wise. So we installed another oil fired HWH - which sips oil and NEVER EVER runs out of hot water!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-22-2009, 03:49 PM   #24
Rewards Points: 126
Originally Posted by Speedy Petey View Post
Where do you find this?
Article 225.30
Old 01-22-2009, 04:32 PM   #25
Res Ipsa Loquitur
My 50gal gas house water heater leaked about a year ago and I too was going the tankless route. I went to my local Lowes and bought the Bosch Aquastar whole house unit. after spending about 1200, I then got it home realizing I needed a specialized venting system for the distance I needed to go which added about another 450+ to the bill (with me doing the install). All in all, I returned the unit, bought a high-efficiency 50 gal gas heater and just replaced the previous one I had in a few hours. I figured I'll keep it as efficient as possible but not need to spend 3x the price with all the additional work!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-22-2009, 05:09 PM   #26
Rewards Points: 270
Off topic but is there such thing as a direct vented tank heater? I do not hear many good things about tankless, BUT I'd like to get rid of my chimney to free up space in the attic to finish it off as living space. This would also give us room for another closet on the first floor... it's not the basement that is valuable real estate but what is above it!
Right now our tank heater goes through the chimney. Everything else is DV or B-power vented or whatever.
pcampbell is offline   Reply With Quote
Old 01-22-2009, 07:41 PM   #27
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You can take the chimneys out of the consideration. New gas water heaters, like the new furnaces are energy efficient and use a power vent through a PVC pipe. No need for chimneys at all.
I would not even consider an electric water heater in my home. To expensive to run and to slow to recover on the tank type. Other than installs, I have no personal experience with on demand water heaters.
Disclaimer: I'm an electrician and not a plumber.
John
jrclen is offline   Reply With Quote
Old 01-27-2009, 12:55 PM   #28
One item that caught my attention was the distance from tank to point of use. My HW tank is in the middle of the house--basically close to neither my bathrooms nor my kitchen(s). I'm not wondering if an electric point of use tankless under the kitchen sink wouldn't be a good idea as the water lines for my kitchen run through an unheated crawlspace. Also, I have a second chimney access from where a furnace was removed that I could use to move the current tank about 15 feet closer to the bathrooms. Still got a gas line there too.
Now the question remains, will a single small electric point of use hot water heater be cost effective in mitigating the heat loss from the long haul through an unheated crawlspace? As for the labor, I'm good on my own and I have the extra capactiy in terms of electrical service.
Maybe I'll just say screw it, keep one tank, take the other tank and make it into a solar batch heater on the roof.
Old 01-28-2009, 11:51 AM   #29
DIYer
You can insulate the pipes you know. Cost of insulation: $5
Old 01-29-2009, 07:43 AM   #30
Gigs,
If you've nothing worthwhile to contribute perhaps consider not contributing. Just so you know, the pipes are very well insulated and also have an electric heat wrap on them as well as they would often freeze in the winter.
Tags
duplex
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Converting Electric to Gas stove LaurynJohnny Appliances 16 03-26-2010 08:08 PM
Converting from Gas to Electric Stove Chloe Appliances 1 06-14-2008 03:06 PM
I'm converting a two family home from oil to gas and need info on... everything. Neep HVAC 3 10-23-2007 08:42 PM
