Converting Brass Chandelier To A Candelabra - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 09:32 PM   #1
Rewards Points: 308
Converting Brass Chandelier to a Candelabra
I'm looking to turn my old brass chandelier similar to this one:
into a candelabra like the one sold here at Restoration Hardware.
Do these just simply unscrew? And also, what would be an effective way to create a base for it to stand up on? Thanks!
smokey847 is offline   Reply With Quote
Old 04-14-2012, 12:18 AM   #2
dmxtothemax's Avatar
Rewards Points: 5,608
Go to the second hand stores and look around for a lamp with a
simulair style base to what you want.
Buy it,
cut the top off,
thread it,
screw it into the base.
paint it black.
done!!!
dmxtothemax is offline   Reply With Quote
Old 04-14-2012, 09:05 AM   #3
Rewards Points: 1,548
Most chandeliers simply unscrew.
There is usually a threaded tube running most of the length of the middle. There may be several ring like hex nuts holding the parts on a few at a time.
You could use a "canopy" or the cap that covers the hole in the ceiling where the chandelier attaches, as your candelabra base. This can be gotten in the Home Depot, etc. electrical department. Optionally add a wood square underneath as shown in your example. The wood would probably have to be at least 3/4 inch thick since there will need to be a recess underneath to hold the end of the threaded tube and one ring hex nut.
Old 04-20-2012, 05:04 AM   #4
The one I've got unscrews easily so hopefully yours is the same. Also I did the same as dmxtothemax said so I would suggest giving that a try.
http://luxrange.co.uk/chandeliers
david143 is offline   Reply With Quote
two dimmers, 1 for spots 1 for chandelier help Nessa Electrical 9 01-31-2012 11:34 PM
brass end cap on brass nipple leaking bjr72 General DIY Discussions 19 11-05-2011 07:10 AM
Replacing Chandelier Green Grounding Wire? wyjadka Electrical 4 03-24-2011 06:22 PM
Carcinogens in brass fittings? cliffspielman Plumbing 7 02-06-2011 01:50 AM
Brass Plated Fixtures rjordan392 Plumbing 5 06-19-2008 09:19 PM
