Converting Aluminum Wiring To Copper ... - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2010, 08:05 PM   #1
Converting Aluminum Wiring to Copper ...
I have a late 1960s house that's being completely renovated. I figure with the walls down, I might as well switch / convert the aluminum wiring to copper.
The following is a picture of the existing electrical box (with aluminum wiring) and a sub-panel the previous home owners added when finishing their basement.
question - can I simply swap the sub-panel for a full size electrical panel - which is fed from the original panel? this way I could gradually turn off the aluminum breakers as I wire the house up in copper (and connect to the new sub panel?)
eventually, the original panel wouldn't have any breakers on whereas the new sub-panel would be powering the entire house (in copper).
any info / advice would be appreciated!
njchan is offline   Reply With Quote
Old 03-14-2010, 09:14 AM   #2
Electrician
Rewards Points: 760
That would work, put in a breaker in the orginal box the same size as your main breaker and then the old panel will act more or less like a disconnect for your new subpanel.
darren is offline   Reply With Quote
Old 03-14-2010, 10:19 AM   #3
Where is the Main feed coming from ?
You want to make sure it will reach the new panel
On a sub you are required to have all the neutrals & grounds seperate
Neutral not bonded to the case
So after you are done & convert the new sub to a Main panel just bond the neutral to the case - usually just a green screw
Old 03-14-2010, 11:10 AM   #4
Master Electrician
Rewards Points: 3,678
My advice would be to try and replace the existing main panel with out removing the existing circuits. Install a new main panel in its place. Temporarily re-feed the old panel from the new panel thus still providing power to the house and giving you time to run the new circuits.
brric is offline   Reply With Quote
Old 03-14-2010, 08:11 PM   #5
thanks for all the tips guys ... I think i'm going to "cut off power" to the existing sub ... and replace it with a new panel - that will be used as a sub panel.
guess I'll need to get a 100amp breaker for the existing main panel to run to the new sub panel. for this, can I use #2 Copper wire?
Splicing Aluminum to Copper Wire dc4nomore Electrical 28 05-08-2012 02:56 PM
Aluminum wiring, copper only devices johnkn Electrical 34 06-08-2009 11:59 PM
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 12:20 PM
aluminum wiring in homes mcvane Electrical 9 02-03-2008 11:40 AM
Aluminum to Copper Leenders Electrical 4 08-21-2006 08:54 AM
