Converting 50 amp to 30 amp
Replace the receptacle (outlet; socket) and also replace the 50 amp breaker down in the panel with a 30 amp breaker. The stove cord and plug remain unaltered.
There could be complications. If the plug for the new stove has neutral and/or ground contacts that the original cable to the old receptacle does not provide conductors for, you would need to string a new 6* gauge 3 conductor plus ground cable down to the panel before you can complete the project.
If only a ground conductor is needed and lacking you can string just a ground conductor to the panel more or less following the route of the existing cable.
* 10 gauge will carry 30 amps but it would be nice to future proof the installation for 50 amps for the next owner of the house.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
