Converting A 4 Prong Dryer Outlet Into A 3 Prong - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 07:37 PM   #1
Unhappy
converting a 4 prong dryer outlet into a 3 prong
we have just moved into a home we are in the process of buying. Our dryer cord is a three prong and the outlet is a four prong, therefore we are needing to changed the outlet to a three prong. the problem is the wires. not sure what to do w/ the copper wire. there is a white, which is the ground wire; a neutral copper wire; and hot wires red and black. please help?!?!
dntbro1994 is offline   Reply With Quote
Old 07-02-2010, 07:56 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the white is the neutral and the bare or green wire is the ground wire.
what you need to do is change the cord and plug on the dryer to a 4 prong. If you look where the cord attaches to the terminals, you should see where the neutral wired connection has a bonding strip or wire that attaches to the frame of the dryer as well. That would need to be removed and the ground wire in the new cord gets attached to the dryer frame. The neutral will go to the terminal where the neutral is currently hooked up and the 2 hot wires to the terminals the hot wires are currently attached to.
Old 07-02-2010, 08:18 PM   #3
the Musigician
DangerMouse's Avatar
And be prepared too.... those cords and plugs cost as much as you paid for the dryer......
DM
Old 07-02-2010, 08:25 PM   #4
nap
You talking to me?
nap's Avatar
they can be pricey. Here is a google shopping page for 4 wire dryer cords to give you an idea.
http://www.google.com/products?q=dry...ire&hl=en&aq=f
Old 07-02-2010, 08:30 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
Yeah I'd change the cord, the 4 prong is the newer standard, I believe. If you ever buy a new dryer it will come with a 4 prong.
Old 07-02-2010, 09:15 PM   #6
nap
You talking to me?
nap's Avatar
If there is a 4 wire recep, they cannot legally change it to a 3 wire anyway.
Old 07-02-2010, 10:44 PM   #7
Electrical Contractor
kbsparky's Avatar
Change the cord = correct procedure.
New dryers do not come with a cord. Those are attached either by the store selling them (or their warehouse/delivery personnel), or by you (or your electrician).
I have found that many such cords are improperly wired as well.
-KB
Old 07-02-2010, 11:21 PM   #8
Wire Chewer
Rewards Points: 68
When I bought my dryer it was already wired, so guess the store may have done it. I would guess it's not that hard if you follow the instructions. Not something you'd want to mess up. I'm guessing the motor needs 120 but the element needs 240. don't want to mix up the connections.
When I bought my house, it came with a FREE! Speed Queen dryer. Starting that thing up was like flipping the main "on" switch to a 1930's warhead factory. It was also hard wired into the panel, guess that's one way to save from worrying about an outlet and cord.
Old 07-02-2010, 11:25 PM   #9
nap
You talking to me?
nap's Avatar
When I bought my house, it came with a FREE! Speed Queen dryer. :
trust me, it wasn't free. You did pay for it somewhere.
Adding a 220v jointer to a dryer outlet popeka Electrical 7 12-13-2009 10:33 PM
Dryer outlet Davide Electrical 3 02-25-2009 12:48 PM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 05:42 PM
dryer Outlet change 3 prong to 4 prong oldpirate General DIY Discussions 2 08-06-2008 07:18 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 05:14 PM
