Converting 3 Prong To 4 Prong On Electric Kiln - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 01:04 PM   #1
Converting 3 prong to 4 prong on electric kiln
I have a 240 volt 50 amp electric kiln with a 3 prong plug. I have a 4 prong outlet for a dryer I would like to use. The kiln has 2 hots and the ground hooked up. Can I hook the new 4 prong cord up and just leave the neutral disconnected? Of course I don't want to burn down the house and wanted an expert opinion
Thanks!
ranger47 is offline   Reply With Quote
Old 05-23-2011, 01:16 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
The rating on the dryer receptacle is 30 amps, and the kiln is rated for 50.
You can not use the dryer receptacle.
jbfan is online now   Reply With Quote
Old 05-23-2011, 01:22 PM   #3
I am a little confused about that because on one place on the kiln it says 50 amps and another place it says 25 amps
Old 05-23-2011, 01:28 PM   #4
Electromagician
sorry but that is electrical hieroglyphics' for man the lifeboats we are way over our heads here.
powerfactor is offline   Reply With Quote
Old 05-23-2011, 04:27 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,892
Well you better figure that out for sure! Look on the rating plate of the kiln where it lists voltage, current, and probably wattage.
mpoulton is offline   Reply With Quote
Old 05-23-2011, 05:24 PM   #6
See below. At the top it says 25 amps, but down below it says 50 amps. Its a cress model 328J kiln but I couldn't find much online.
Old 05-23-2011, 06:02 PM   #7
Lic Elect/Inspector/CPO
If you go to the cress website you will see that it a 50 amp outlet
NJMarine is offline   Reply With Quote
Old 05-23-2011, 06:13 PM   #8
So I emailed Cress and they said, "Go with the top decal, 25 amps." Also the real model number is B23H which is closest to this one
Old 05-23-2011, 07:10 PM   #9
go with the mfg says
Old 05-23-2011, 07:24 PM   #10
So back to my question. The kiln has 2 hots and the ground hooked up. Can I hook the new 4 prong cord up and just leave the neutral disconnected?
Thanks!
Old 05-23-2011, 08:40 PM   #11
Sparky
Rewards Points: 510
Yes
make sure you tape the end, though
Techy is offline   Reply With Quote
Old 05-23-2011, 09:03 PM   #12
It requires 25A. The lower label is on the Kiln Sitter, which is a completely separate device made by a separate company and installed as part of the kiln. The Kiln Sitter is a timer and automatic shutoff (using pyrometric bars) for the kiln, and the 50A rating is it's maximum allowable load. The upper nameplate is for the kiln itself, and says 25A.
Use a 4-wire cord and leave the neutral (white) disconnected.
Old 05-23-2011, 09:31 PM   #13
The hots on the old cord are both white. Does it matter which one goes where (red and black)? I will connect green (ground) and leave white disconnected.
Old 05-23-2011, 11:00 PM   #14
The hots are interchangeable. Just make sure the ground goes to the frame.
Converting Gas Stove to an Electric Stove? LooptieLu Electrical 8 01-07-2011 11:20 AM
converting a 4 prong dryer outlet into a 3 prong dntbro1994 Electrical 8 07-02-2010 11:25 PM
Converting Electric to Gas stove LaurynJohnny Appliances 16 03-26-2010 09:08 PM
Converting duplex to single family--what to do with electric services? zamoti Electrical 32 01-29-2009 04:16 PM
Converting from Gas to Electric Stove Chloe Appliances 1 06-14-2008 04:06 PM
