Converting A 220V Two-gang Outlet To 110V - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 04:01 AM   #16
Semi-Pro Electro-Geek
Rewards Points: 2,944
Originally Posted by kevindd992002 View Post
How do you call the output terminals of that transformer then? Are they both live?
If it's just a plain transformer with no case or receptacle, then the output is floating with respect to ground and neither conductor is "hot" or "neutral". They're just two wires with 120V between them. If the transformer is in a case with a receptacle and cord, then one of the output terminals will probably be bonded to ground. That's the neutral. The one with 120V with respect to ground is hot.
All your 12V DC adapter needs is 120V between the two prongs.
It would still be easier to just get a 240V to 12V adapter and put DC the connector from the old adapter on it so it fits your device.
mpoulton is offline   Reply With Quote
Old 09-30-2011, 04:11 AM   #17
My transformer is actually similar to this one: http://www.google.com/imgres?q=panth...:0&tx=56&ty=63 . It has a case, a two prong cord that plugs into my 220V outlet (three-prong) and a two-prong output receptacle. So I guess this is a floating output?
kevindd992002 is offline   Reply With Quote
Old 09-30-2011, 06:17 AM   #18
Seems likely. If the input doesn't have a ground connection, then both the input and the output will be floating.
Converting 220v dryer to 110v dbielinski Appliances 17 09-05-2012 05:45 PM
converting a 220V circuit to a 110V outlet jacknc Electrical 1 06-27-2011 12:24 PM
110v outlet from 220v line emstype Electrical 4 06-27-2011 12:58 AM
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 01:16 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
