Converting From 220v To 110v - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 02:40 PM   #1
converting from 220v to 110v
I have a micromega cd player and would like to convert from 220/240 50htz to 110v 60htz, is it a case of just changing the power supply and if so where can I buy one in the uk. Thanks
steven h is offline   Reply With Quote
Old 11-16-2008, 02:49 PM   #2
steven, I have to wonder if you are serious because when I viewed your question there were three ads on the top of the page for these converters.
Maybe google has some intellegence to its ads and somehow re-directs the ad content to reflect the content of the page.
Master Electrician
jwhite is offline   Reply With Quote
Old 11-16-2008, 04:14 PM   #3
Google uses ads that find key words in the posts. This sounds like a real question
jerryh3 is offline   Reply With Quote
Old 11-16-2008, 05:51 PM   #4
Yes you can, get a special step-down transformer. The frequency shouldn't matter much.
Check the products here out, they have some converters
http://www.voltage-converter-transfo...converter.html
rgsgww is offline   Reply With Quote
Old 11-16-2008, 07:49 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
um, yes, freq can matter, a lot. a 50 hz motor will run 20% faster when using 60 hz so everybody is going to end up with a little "chipmunk" singing going on.
Old 11-16-2008, 08:02 PM   #6
Rewards Points: 2,350
Nah. The power supply in the device will rectify the incoming power to DC anyhow.
Old 11-16-2008, 08:21 PM   #7
Rewards Points: 6,652
I actually do not get the ad's because I have blocked the pagead2.googlesyndication.com as a restricted site in IE8. As for the OP, the adverts can lead to SPAM sites, not true helpful sites.
Old 11-16-2008, 08:27 PM   #8
nap
You talking to me?
nap's Avatar
that is why I qualified it. If the motor is DC, then I will still argue the speed issue because the RMS of 60 hz is going to cause it to be a higher DC voltage that rectified 50 hz. Voltage affects speed of many DC motors.
without a lot of info, it is impossible to make any real determination but suffice it to say, the freq is of concern and should not be written off so easily.
Converting 220v dryer to 110v dbielinski Appliances 17 09-05-2012 06:45 PM
Convert 220V to 110V wrldruler Electrical 13 09-15-2008 12:55 PM
110v vs. 220v gunboatbay Electrical 17 05-15-2008 09:09 AM
220v to 2 110v ? Astoldt Electrical 5 12-28-2007 09:16 PM
220v from 110v leboyd Electrical 6 03-19-2006 09:51 PM
