Converting A 220 Line To 110. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 06:50 PM   #1
Converting a 220 line to 110.
I need more outlets in my older condo and want to take the electric base heaters out and use that system to make outlets. Can I convert one of the hot wires to a neutral wire? If so how do I go about making the circuit work?
ulmerj is offline   Reply With Quote
Old 03-05-2011, 07:22 PM   #2
Electrical Contractor
kbsparky's Avatar
Umm ... what will you do for heat once the baseboard units are gone?
-KB
Old 03-05-2011, 07:59 PM   #3
I=E/R
a7ecorsair's Avatar
If the 240 volt baseboard heaters are wired with cable where the white wire has been remarked as a hot using black tape, you could remove the tape at both ends, move the white wire to the neutral bar and connect the black to a single pole breaker. That would give you 120 volts but no heat.
a7ecorsair is offline   Reply With Quote
Tags
20 amp outlet , convert 220 , neutral wire
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Natural gas line????? figs Plumbing 1 06-14-2009 01:13 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
