Converting 2-prong Outlets To 3-prong - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2013, 03:31 PM   #1
Rewards Points: 14
Converting 2-prong outlets to 3-prong
I have read several posts, on this web site about changing 2-prong receptacles to 3-prong receptacles. I am still confused if I can safely do the following: My daughter's recently purchased 1952 home with BX cable (2 conductor) wired (with steel boxes) has all 2-prong receptacles, except in the kitchen where there are GFCIs. With each 2-prong outlet, if I first determine that I have a proper ground between the hot conductor and steel box (by using a 100w incandescent bulb as my tester). Then next, if I affix a ground wire pigtail to the back of the steel box and to the new 3-prong receptacle ground screw, will this serve as a proper and safe grounded 3-prong receptacle?
MJJK is offline   Reply With Quote
Old 01-02-2013, 03:33 PM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Just put in a gfi with a label on it saying " ungrounded"
eastcoastsparky is offline   Reply With Quote
The Following User Says Thank You to eastcoastsparky For This Useful Post:
MJJK (01-02-2013)
Old 01-02-2013, 03:40 PM   #3
Rewards Points: 14
Thank you, I do realize that your suggestion is another alternative to my situation.
Old 01-02-2013, 04:01 PM   #4
Licensed electrician
Rewards Points: 1,876
You will need to determine if your cable has the thin bond wire that allows the cable to be used as a grounding means. Look near your panel at the cables.
Old 01-02-2013, 04:02 PM   #5
Rewards Points: 150
Putting a ground to the back of the box would serve no purpose its either ghe gfi or a rewire which is something to consider in the future
Sent from my iPhone using DIY Forum
Old 01-02-2013, 04:12 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,608
This will only work if the steel box (j box) is properly earthed.
I am not sure what code says,
as it varies from area to area.
dmxtothemax is offline   Reply With Quote
Old 01-02-2013, 04:12 PM   #7
Rewards Points: 258
About 25 years ago I was faced with a similar problem and basically I handled it as the OP did. I definitely had that thin uninsulated third wire that ran along side the hot and common. Having checked the outlet with a meter (hot and ground) I was convinced the outlet was grounded. I am not suggesting that this meets present code and if it does not of course I would like to know that as well. I reasoned that the service panel was grounded and that the metal cable carried the ground to the outlet box. In my visits to the big box store I later found that there are outlets that ground w/o a ground wire to the green screw but they cost a bit more and must only be used with a grounded metal box.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 01-02-2013, 04:36 PM   #8
Oso954's Avatar
Rewards Points: 1,646
The thin bonding strip is the key. If you have it, the armoured cable can be used as the ground. A jumper from the box to the outlet can be added.
If the bonding strip does not exist, it cannot be used. Even if you get the test light to light showing that some "ground" exists, it is unsafe/against code to use it.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
retired guy 60 (01-02-2013)
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 07:56 AM
Changing two prong electrical outlets to grounded three prongs Jabar714 Electrical 4 12-21-2010 01:14 AM
Replace 2 prong outlets with 3 prong outlets rpsjn4 Electrical 27 01-17-2010 01:34 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 12:59 PM
