Converting 2 Prong To 3 Prong Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 11:27 AM   #1
Rewards Points: 135
Converting 2 prong to 3 prong outlets
A friends house was built in 1962. There is a 100A service panel. Circuit wiring is cloth covered romex 12/2 and 14/2 with ground that appears to be 18ga but not sure-definitely smaller than 14ga- somebody here probably knows what was standard then. All outlets are 2 prong with metal boxes grounded. Ground wires are connected to ground buss at panel. Can I convert to 3 prong using the existing ground wire if it is 18ga?
elmaur is offline   Reply With Quote
Old 04-24-2013, 11:35 AM   #2
jproffer's Avatar
Rewards Points: 706
Say what???
14/2 would be 14g, 12/2 would be 12g....so if it's 18g then it's not 14/2 or 12/2.
To answer, if the ground wire goes all the way back to the panel then yes, you can use that to ground 3 prong receptacles.
EDIT: Nevermind about the first part. I know what you mean now. I think the ground is allowed to be a certain amount smaller than the H & N conductors, but not sure how much smaller....one of the pros will be along and be able to tell us both
jproffer is offline   Reply With Quote
Old 04-24-2013, 11:37 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 384
16 gage ground wires from back in that day.
It is not legal today to use a smaller ground for 15, 20 and 30 amp circuits, than a 14, 12, and 10.
The Following User Says Thank You to jbfan For This Useful Post:
jproffer (04-24-2013)
Old 04-24-2013, 11:51 AM   #4
Rewards Points: 135
I assume if it is not legal there is a safety concern? If so what is it?
Old 04-24-2013, 11:55 AM   #5
jbfan's Avatar
Rewards Points: 384
The concern is the undersized ground wire could not handle the fault current.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 07:56 AM
Changing two prong electrical outlets to grounded three prongs Jabar714 Electrical 4 12-21-2010 01:14 AM
Replace 2 prong outlets with 3 prong outlets rpsjn4 Electrical 27 01-17-2010 01:34 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 12:59 PM
