Old 12-04-2008, 09:58 AM   #1
Converting 15 Amp circuit to 30 Amp
I want to replace a standard bathroom vent fan with one that has a heat lamp. This involves upgrading the circuit from 15 to 30 Amps.
What is involved in doing that?
Greytguy is offline   Reply With Quote
Old 12-04-2008, 10:00 AM   #2
joed's Avatar
Start from the beginning. Nothing on the 15 circuit can used over.
Use #10 wire and a 30 amp breaker.
Old 12-04-2008, 12:02 PM   #3
Have to run new wire, run 10 awg.
rgsgww is offline   Reply With Quote
Old 12-04-2008, 12:20 PM   #4
I was afraid of that- not nearly as easy a project as I hoped!
Thanks.
Old 12-04-2008, 01:41 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
There is NO WAY this heat lamp will require a 30A circuit.
Who told you it would?
Old 12-04-2008, 01:49 PM   #6
Send a message via AIM to theatretch85
I was wondering the same thing. It would have to be an actual heater (not just a screw in heat lamp). How many watts does this heater/heat lamp use?
theatretch85 is offline   Reply With Quote
Old 12-04-2008, 01:53 PM   #7
I was in a hardware store looking at combo fan/heat lamp units and the box of the model I was interested in appeared to indicate that it required 30A.
I am really weak in the area of electrical work. Could I have read it wrong? If there are units out there that will run on 15A that would be great- then I am back in the DIY realm.
Old 12-04-2008, 01:59 PM   #8
Just did some more searching on the web and I found a Nutone with a 1500 watt heat element and 100 watt (max) bulb and 70CFM fan (Model 665RP) that only requires 12.5A
Problem may be solved....
Old 12-04-2008, 02:22 PM   #9
DIYer
This is not possible, they lied.
12.5 A is 1500 watts, leaving nothing for the motor or light.
However, it is believable that all that is under 15 amps, just barely. Only do that if there's nothing else on that 15 amp circuit or you'll get breaker trips randomly.
Gigs is offline   Reply With Quote
Old 12-04-2008, 02:54 PM   #10
1500W figure came from a 3rd party website. Nutone installation guide says the heat coil is 1300W. With a 100W bulb max, total is 12.5A.
Old 12-04-2008, 03:25 PM   #11
I have to say, pretty much every one of those heat/fan/light units I have installed required a dedicated circuit. Some 15A, some 20A.
Old 12-04-2008, 04:05 PM   #12
You might need to pull a new line, depends on what feeds your fan.
Old 12-04-2008, 04:16 PM   #13
If you want the 3 functions to operate independantly, you're going to have to pull a new feed from the switch to the light. You'll need four conductors(plus ground) from the switch to the unit.
jerryh3 is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
