-   -   converting 120 to 240 for dryer (http://www.diychatroom.com/f18/converting-120-240-dryer-156557/)
CarrieD 09-11-2012 07:23 PM
I just moved into a new (old) rental house and have a utility closet with all the correct hook-ups except only a 120 plug and no 240 anywhere in the house. The interesting thing is that in the fuse box, the fuses marked dryer is a double bar and it appears to operate that plug. Could someone have put a 120 where a 240 was? Will this be easy to switch? Thanks for your help.
stickboy1375 09-11-2012 08:19 PM
12 Attachment(s)
Take a picture? It would help...
DannyT 09-11-2012 08:22 PM
maybe they had a gas dryer and only needed a 120 plug. a photo of the outlet and another showing what is in the box behind it would help.
stickboy1375 09-11-2012 08:24 PM
12 Attachment(s)
Personally since this is rental, make your land lord address this issue...
dmxtothemax 09-12-2012 05:34 AM
Can you tell us how many wires are behind the 120v outlet ?
and what color are they ?
Also what wires and colors are at breaker end ?
brgmgb 09-12-2012 09:45 AM
1. Turn off the breaker.
2. Verify there is no power to the 120 receptacle
3. Take the cover off the box.
4. Unscrew and pull the receptacle out of the box.
5. Look to see how many wires are in the box.
I suspect that you will find four wires - black, red, white, and ground with pigtails from the black and white conductors and a wire nut on the red conductor.
Post what you find.
