Converting 12 V Light Fixture To 110 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 02:02 PM   #1
GKA
T5 wedge type 12 volt bulb
I have a light fixture which is rated for 120 volts but currently has a 12 volt T5 wedge type bulb in it (921) Does anyone know what the proper bulb number/name would be for 120 volt bulb? I have been told by an electrician that since the fixture is rated for 120 V, I just need to find the proper bulb to make it work. Any one know what the bulb would be OR where I can find a "table" that would let me import the 12 V info and provide me with 120 V equivalents? Thanks
GKA is offline   Reply With Quote
Old 06-30-2011, 07:59 PM   #2
Rewards Points: 1,418
Note that the wattage you are going to use should not exceed the wattage of the original 12 volt lamp. You will need to replace the lamp socket, also, with a socket used for 120 volt lamps.
Still, you will void the Underwriters Laboratories or other safety rating of the fixtures and if you shoul have a fire, the insurance might not cover. For this and other reasons, they do not make conversion kits (except for fixtures that are really dual voltage); you would have to jury rig the new socket and other applicable parts.
The Following User Says Thank You to AllanJ For This Useful Post:
GKA (07-01-2011)
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Replacing a Light Fixture with many wires flan3084 Electrical 7 12-31-2010 12:37 PM
Mercury Vapor Light Fixture Wiring Hoppy084 Electrical 4 06-25-2010 12:38 AM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 09:20 PM
light fixture wiring jasjks Electrical 4 11-29-2006 03:51 PM
