Convert Three Phase Into Monophased? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2008, 12:41 PM   #1
Convert three phase into monophased?
Hi,
I found a cable in my fireplace which I think was used by the previous owner for an electric heater. I would like to use the cable in monophased, it has three brown wires and a yellow/green one which must be earth (I live in UK BTW) but it has no neutral. I was planning to connect one of the phases and the neutral to a female socket.
Is there a way I can safely use this cable for a monophased socket even if there is no neutral?
Thanks for your help
Ju
begemoth is offline   Reply With Quote
Old 09-28-2008, 02:48 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a neutral is a neutral because what you attach it to.
Typically, in this country, using such a cord would require re-identyifing one of the conductors as a neutral (blue over there?) and utilizing it as such.
The spare conductor simply would not be attached to anything and insulated to prevent a accidental short.
Old 09-29-2008, 10:56 AM   #3
Hi nap,
Thank you for your help, I'll try connecting one of the two remaining wires to the neutral pole of the socket as you recommended
Bege
120/208/1 phase wiring questions JohnJon Electrical 11 09-01-2008 12:28 AM
3 Phase Converter Wiring ideffects Electrical 22 05-26-2008 09:05 PM
changing single phase to 3 phase bentaypink Electrical 10 12-15-2007 04:23 PM
3 phase electricity J187 Electrical 11 10-26-2006 02:40 PM
