Convert Plug In Light With Screw In - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2008, 12:15 AM   #1
convert plug in light with screw in
I have 2 of these fixtures together in my ceiling... http://www.egaynor.com/_get_item.php...285A%204%20PIN and I want to replace them with one screw-in style fixture. Here's my problem... one lampholder has a yellow, yellow w/ black stripe, and two red wires, the other has a yellow, yellow w/ black stripe, and two blue wires. All of the wiring is 18 Guage, which from what I understand is kind of small. Any help of how to convert this would be greatly appreciated.
hornet1946 is offline   Reply With Quote
Old 01-28-2008, 02:05 PM   #2
How many watts will the new lights be?
Is there more than one light switch that turns these one?
redline is offline   Reply With Quote
Old 01-28-2008, 04:33 PM   #3
Rewards Points: 826
Those are flourescent fixtures and the wires you describe come off the ballast recessed in the ceiling. You cannot convert to a screw-shell type socket. You'd have to replace the entire fixture.
LawnGuyLandSparky is online now   Reply With Quote
Old 01-30-2008, 09:58 PM   #4
There is only one switch and the bulb is 60W.
I have removed the entire fixture. I have a new one to install. The wiring is what's throwing me. There's just an enclosed bundle of wires now.
Old 01-31-2008, 04:41 PM   #5
Rewards Points: 826
If the bundle of wires are the colors you describe above, you have not removed the entire fixture, just the trim & the "can."
Old 01-31-2008, 07:00 PM   #6
" Euro " electrician
frenchelectrican's Avatar
are you talking about this one ???
http://img2.timeinc.net/toh/i/a/elec...-lights-01.jpg
If so. the only way is swap the whole luminiare to correct one if you can get above like in attic it pretty easy to get in there other wise there is other way to remove it but it will be little messy along the way.
before i will expain it i want to make sure if this is a hardwired flourscent luminaire first because there is a ballast mounted on it.
Merci, Marc
how do I remove light and plug plates catara Painting 6 01-01-2008 11:29 PM
Shed: One light, one plug Crackers Electrical 2 08-31-2007 06:09 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 01:34 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
