Convert From Outdoor Recessed Can To Hanging Pendant - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 04:20 PM   #1
Convert from outdoor recessed can to hanging pendant
I currently have a flood light in a recessed can for my ceiling light on my front porch. I want to convert this to a hanging pendant lamp. The pendant lamp would normally hang from a junction box. How can I convert the recessed can into a ceiling level junction box?
Once I figure that out, because the hole for the recessed can light is about 3 inches larger in diameter than the ceiling canopy on the hanging pendant, I plan to use a ceiling medallion to cover the gap.
Also, what is the recommendation as to how low the light should hang in relation to the front entry (a double door with an eyebrow window above it)?
Silkcityflorida is offline   Reply With Quote
Old 12-02-2011, 04:33 PM   #2
Rewards Points: 13,732
Center of the door.
They sell adapter kits in the lighting dept. at Lowes and Home Depot.
Old 12-03-2011, 11:25 AM   #3
Thank you for the info about finding the conversion kit at Home Depot. I just picked one up.
But your other response, "Center of the door" confuses me. I realize the light should line up with the center of the door, but my original question was, "what is the recommendation as to how low the light should hang in relation to the front entry". Should the bottom extend down to the top of the door opening? Should the body of the light be centered vertically on the eyebrow window? What is the usual configuration?
Tags
light conversion
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 11:21 AM
hanging Mirir on door txmike Carpentry 9 08-02-2009 09:01 AM
Hanging punching bag in garage Isocene General DIY Discussions 3 05-21-2009 08:20 AM
Do I need to ground a pendant light? Rendulic Electrical 5 05-10-2009 01:17 PM
