Convert Old (nasty) Switch To Switch/outlet? (have Pics) - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 07:45 PM   #1
Convert old (nasty) switch to switch/outlet? (have pics)
Hi,
I have read through some of the threads on how to do this. But I'm confused...
1) because I am a total newbie
2) because the wires running into this switch aren't white, black, or red...they are old and covered with cloth.
Can I convert the switch to something like the switch/outlet below?
to something like this...
3rd_times_charm is offline   Reply With Quote
Old 01-26-2010, 08:03 PM   #2
If that is only 2 wires in the box then no
How many wires in the box ?
Do you have a meter to test for voltage ?
Old 01-26-2010, 08:15 PM   #3
Thanks Scuba Dave,
There are only two wires, I don't think they actually installed a box as I have seen before; here there is simply a hole in the wall. So I guess the big problem is that I don't have a 'ground' wire, here, is that right?
No, I don't have a meter. I was hoping I might just switch off the fuse, install a different piece, and be in business.
Old 01-26-2010, 08:32 PM   #4
Learning by Doing
Leah Frances's Avatar
Third - the problem isn't that you don't have a ground. It's that you have what's called a switch leg. The two wires only control the on/off for the light fixture.
Essentially, you do not have any 'power' for the receptacle.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-26-2010, 08:35 PM   #5
Yup, just a switch loop
Basically just a hot wire that the switch connects/disconnects
You don't have a neutral or a ground
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
ceiling fan works, but light doesn't egildone Electrical 2 09-22-2009 11:20 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
