Convert Illuminated Switch To Timer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 12:48 PM   #1
convert illuminated switch to timer switch
Hi,
I tried to convert an illuminated switch to a timer switch. You can find the wiring diagram of the current illuminated switch here.
The timer switch that I purchased had a red, white, black, and green wire.
I wired white to white, black to hot black, green to gnd, and load to one and both of my load lines in the picture. The timer switch light lit up but the led read out did not work and it did not turn any lights on! I am really confused.
Do I need a new timer switch? Can I even use a timer switch in this config? I see that some leviton switches can have 2 travelers... can I wire my 2 loads to these ?
J
t6joe is offline   Reply With Quote
Old 04-23-2013, 01:52 PM   #2
Rewards Points: 734
What model timer switch did you buy?
AandPDan is offline   Reply With Quote
Old 04-23-2013, 02:40 PM   #3
I bought this one
http://waterheatertimer.org/Program-...c-LW60418.html
Old 04-23-2013, 02:48 PM   #4
Rewards Points: 734
OK,
So you've connected the black and white wires from the breaker to the black and white wires on the switch. You've connected the red wire on the switch to the black wire on your load. Is the white wire from the load connected to the neutral?
Old 04-23-2013, 02:54 PM   #5
That's correct:
Black on the switch goes to the hot black wire from breaker
White on the switch goes to neutral in the box
Red on the switch goes to black load
I'm assuming that white from the load is tied up in the neutral from the box as there is a large wire nut with lots of white wires
Old 04-23-2013, 02:59 PM   #6
Rewards Points: 734
Are you absolutely positive that the black wire you have feeding the switch, from the breaker, is correct? You didn't accidentally swap it with the black from the load side?
Do you have a meter?
Old 04-23-2013, 03:37 PM   #7
I'm sure:
Here's what I did.
I ran the meter from my hot light bulb to the load black and it beeped.
I disconnected all the wires from the switch, turned the breaker on and tested the black hot and it read ~110 V. The other two blacks were dead.
Old 04-23-2013, 03:40 PM   #8
Rewards Points: 734
It might be a bad switch. It appears to be wired correctly and you do say the LED readout isn't working.
Old 04-23-2013, 04:15 PM   #9
The on/off button lights up but the lead readout doesnt work
3-Way Switch Confusion / Convert to GFCI natedro Electrical 7 07-28-2012 06:07 PM
Timer switch at end of run tmaher Electrical 3 05-16-2011 07:06 AM
Timer Switch Hookup Yankee1423 Electrical 6 02-05-2011 10:02 PM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 12:02 PM
How to install leviton 6230 timer switch diydan Electrical 12 05-27-2009 10:52 PM
