Convert Battery-powered Device To AC - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 07:47 AM   #1
Convert battery-powered device to AC
I have a small camera that uses a single Lithium CR123A battery to operate. I'd like to be able to plug this into an electrical outlet instead. Can anyone help me with step by step instructions and type of adapter needed? Thanks in advance!
TLo70 is offline   Reply With Quote
Old 11-19-2011, 09:24 AM   #2
Boston Fan, get over it
Toofarfromfenwa's Avatar
Depending on the camera, it may have a spot on the side of the camera for an AC power adapter. If it does, you can pick up an adapter at most Best Buy or Radio Shacks.
Toofarfromfenwa is offline   Reply With Quote
Old 11-19-2011, 10:07 AM   #3
Nope. No power adapter spot.
Old 11-19-2011, 02:02 PM   #4
It would be very difficult, and somewhat pricey. My advice, if money allows, is to buy a new camera.
Old 11-19-2011, 06:58 PM   #5
Rewards Points: 502
I'd probably get a DC power adapter of the correct voltage, the solder the wires to the contacts
forresth is offline   Reply With Quote
Old 11-19-2011, 08:55 PM   #6
Rewards Points: 788
if you do that dont forget to remove battery or it could explode!
carmusic is offline   Reply With Quote
Old 11-19-2011, 11:20 PM   #7
Rewards Points: 502
yup. lithium batteries like to do that from time to time
Old 11-20-2011, 02:58 PM   #8
How do I determine the correct voltage of the adapter? Can you recommend an adapter? Also, is it really as simple as just splicing the two adapter wires and attaching them to the battery terminals? If so, one wire to each terminal?
What is the best electric or battery powered caulk removal tool? dmauldin Remodeling 3 10-02-2011 07:15 AM
AD/DC adapter for Battery Powered Device JonReeves Electrical 25 09-20-2011 04:35 PM
Converting a battery operated device to an AC adaptor rblissaz Electrical 6 09-18-2011 12:48 AM
Making a battery powered device work with an AC/DC adapter? FlyGuy Electrical 14 11-21-2010 07:28 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
