Old 11-21-2008, 10:43 PM   #16
convert 220 outlet to 110?
I found the place where the black/red is connected to the black/white. I went thru every junction on the lower level of my house (which took forever, since I was changing outlets and switches as I went) and did _not_ find it. Then I started thinking about how they could have done this after the house was built and it suddenly dawned on me that they'd almost certainly have had to go thru the crawl space. Sure enough, there it was, and really easy to access. Once I found it, it was a very simple mod. Now I have one outlet (that I'll probably rarely, if ever, use) that's on it's own dedicated circuit.
Thanks for all of the help. This forum has been extremely useful for me, and I've only been posting here for a few days...
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 11-22-2008, 12:03 AM   #17
You have a double pole breaker in there? Its safer.
rgsgww is offline   Reply With Quote
Old 11-22-2008, 12:29 AM   #18
Send a message via AIM to theatretch85
If he is only using one 120 volt outlet then it is perfectly fine to be using a single pole breaker. Just cap the red wire in the panel and at the junction box, and cover the empty space in the panel with a blank cover or leave the other breaker in there as a filler and just not connect anything to it.
theatretch85 is offline   Reply With Quote
Old 11-22-2008, 12:59 AM   #19
Yeah, I was assuming he was using the red wire aswell, and just broke the tab.
Old 11-22-2008, 09:57 AM   #20
I detached the red wire from the breaker and am using it as the neutral. At both ends, I covered it with white electrical tape.
Old 11-22-2008, 11:10 AM   #21
The double pole breaker comes in if you someday decide you want to run two circuits on that 3 wire cable. If the neutral is shared, the two circuits must use a double pole breaker, so that they're on opposite legs, keeping the current in the neutral below the rated value.
KE2KB is offline   Reply With Quote
Old 11-22-2008, 11:11 AM   #22
Originally Posted by Gigs View Post
His vanity call of K2KGB is still processing.
Actually, I was thinking of getting a vanity call (not K2KGB though <g>), but decided I would wait until I get my extra class. That's something still in planning. At least now I don't have to take another (morse) code test<g>
Old 11-22-2008, 11:19 AM   #23
I thought you had a red, black and white wire exiting the panel and running to that junction box and a black and white wire exiting the junction box and going to the outlet location. I would have disconnected the red wire, and attached the white wire coming from the outlet to the white wire in the junction box going to the panel. Then just cap the red wire on both ends. This would have been the most preferred way of doing this.
Old 11-22-2008, 11:39 AM   #24
DIYer
I still have my technician call even though I'm general. I'm non-operating lately though.
Gigs is offline   Reply With Quote
Old 11-22-2008, 10:00 PM   #25
That's a good point. When I opened up the access point in the crawl space there were a bunch of wires in there, but only one white, and it was a heavier gauge (it seems to go with a heavy red/blue pair that's not being used for anything). There are some other access points in the crawl space, so maybe I'll try to track down that white wire when I get a chance. In any case, it works and I've got a lot of other problems to solve that are much higher priority than this (unless, that is, someone can convince me that it's crucial to know what happened to the mysterious missing neutral...).
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Convert an Outlet into a Switch? Geo747 Electrical 3 07-08-2007 11:23 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
