-   -   Convert 220 to 110 (http://www.diychatroom.com/f18/convert-220-110-a-26727/)
Chet 09-12-2008 04:27 PM
Convert 220 to 110
I have a 220 line in the garage and would like to convert to 110 line,
There is a box on the wall. What would be the easiest way to make this conversion.
jerryh3 09-12-2008 04:38 PM
What was the box used for before? How many wires are in the box? Detached or attached garage? Size of wires?
Chet 09-12-2008 05:47 PM
convert 220 to 110
The box has a receptiable coming out and was used for a air compressor.
Can I remove the box, run the 220 line into a breaker box and run 1 couple 15 amp breakers out of that.
This is in my son's garage (he just bought the house) and I'm not sure what size the wires are.
jerryh3 09-12-2008 07:15 PM
Most likely you won't be able to do that. There is probably only three wires at the box now(grounding, 2 ungroundeds). You could use the existing wires to convert to a 120V outlet by switching the existing breaker feeding the circuit to a single pole breaker and wiring a 120V receptacle at the box. There are few things you'll need to verify before doing this(wire size, etc.). Is this a detached garage?
Chet 09-12-2008 07:31 PM
I appericate your help. Its an unattached garage with a breeze way. I will be going over there tomorrow and will have more information and a better discription. I will reply more when I get that.
Thanks again for your hellp..
220/221 09-12-2008 07:38 PM
PICTURES!!
Your 240V circuit has two hot wires coming from a double pole breaker.
A 120V circuit would have one hot coming from a single pole breaker and one neutral coming from the neutral bus at the panel.
There may or may not be a ground wire involved.
Sometimes it is very easy to change 240 to 120 by changing one of the hots to a neutral.
Need more detail on the wire type. Open the recep box and look at the wires inside. How many wires? Is there a ground? If so, is it bare? Is one wire white?
