Convert 110v To 220v - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 07:19 AM   #1
convert 110v to 220v
how do i convert an existing 110v outlet to 220v?
Hayseed is offline   Reply With Quote
Old 12-01-2010, 07:27 AM   #2
Is it a dedicated circuit to that outlet ?
Old 12-01-2010, 08:06 AM   #3
Electrician
Unless it is a dedicated circuit, like a receptacle installed specifically for a wall air conditioner, you can't convert. Your best bet is to run a new line.
The reason you can't convert it if it isn't a dedicated circuit is that you would also be converting every other receptacle or light on that circuit to 240V, which would NOT be good
VersaBar is offline   Reply With Quote
Old 12-01-2010, 07:29 PM   #4
My suggestion is to call in an electrician. It doesn't appear from your question that you have enough knowledge to be running and connecting electrical circuits. That being said good luck on your endeavor.
merle is offline   Reply With Quote
Old 12-01-2010, 07:30 PM   #5
Electrician
DIYers have to start somewhere. This is actually a pretty straight forward task that can be explained pretty easily, as long as it's a dedicated circuit.
220v vs 110v Baseboard Heater?? Master Brian Electrical 8 11-19-2010 11:13 PM
220v to 110v extension cord? glamabilly Electrical 14 09-25-2010 11:25 PM
Convert 220V to 110V RCCarpetCare Electrical 2 03-15-2010 08:52 PM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 10:46 PM
Convert 220V to 110V wrldruler Electrical 13 09-15-2008 11:55 AM
