Conversion 2 Prong To 3 Prong - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 05:31 PM   #16
Licensed electrician
Rewards Points: 1,494
You have one pair coming in and two cables going out in that one box. There should not have been two wires under the screw head. Pigtails should have been used.
Your wiring looks too old to be grounded.
MTN REMODEL LLC (05-29-2013)
Old 05-29-2013, 06:00 PM   #17
Rewards Points: 150
I would strongly recommend an upgrade on your wiring this older wiring will often become brittle especially in lighting outlets.
RIP EJT
usair is offline   Reply With Quote
Old 05-29-2013, 10:29 PM   #18
Originally Posted by MTN REMODEL LLC
Splinter...,. If I understood you correctly in post 3 I think, your objective and interest is in having three prong recepticals, and you don't really care if they are grounded ... Right (TV and stereo don't usually demand grounds)
A lot of TV's do require grounds. Surge protector power strips require a valid ground in order to function and protect your expensive electronic equipment. Those orange 3-prong to 2-prong adapters don't do anything in the absence of a valid ground other than allow you to plug a 3-prong plug into a 2-prong receptacle.
clydesdale is offline   Reply With Quote
Old 05-30-2013, 04:44 AM   #19
Bill Kearney
Rewards Points: 1,174
Don't be handling that wire too much. It gets brittle over time and you could end up creating a spark/fire hazard inside the box when you try to stuff the brittle old insulation back in there.
You won't like to hear it but if you want genuine grounded outlets then you're going to have to get new wire pulled from the outlets back to the breaker panel.
wkearney99 is offline   Reply With Quote
2 Prong Oulet conversion to 3 Prong Grounded srusten Electrical 2 12-05-2011 03:04 PM
3 prong to 4 prong dryer conversion ccm9fc Electrical 2 11-01-2011 10:41 AM
Creating a ground for a 2 => 3 prong conversion MikeBz Electrical 8 10-20-2011 09:50 PM
3 prong to 2 prong capacitor conversion hotandmad HVAC 6 07-03-2011 06:41 PM
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 08:59 PM
