Controlling A Gfci Outlet With A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 06:04 PM   #1
controlling a gfci outlet with a switch
Hello:
This is my first post and I'm confused.
I am trying to control a gfci outlet using a switch. I have connected the switch on the power side of the outlet. The panel breaker (non-afci) on that line keeps tripping when I activate the switch.
I have interrupted the black wire as expected at the switch and then sent it onto the "line" side (brass screw) of the gfci. The neutral (white) then runs back from the "line" side (silver screw) and past the switch to the panel.
All grounds are connected.
Why is breaker sensing an overload?
Thanks so much for the help.
libby
libbysorcum is offline   Reply With Quote
Old 03-22-2013, 06:10 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
It's not sensing an overload, it's sensing a short circuit. Something is wired wrong, or a hot is touching a ground (or neutral) somewhere.
Old 03-22-2013, 06:10 PM   #3
Rewards Points: 13,694
What room is this that you need a GFI?
GFI's do not since over loads, they since an unbalanced load.
Circut breakers since an overload.
http://home.howstuffworks.com/question117.htm
Old 03-22-2013, 06:12 PM   #4
Joe. From the OP:
Old 03-22-2013, 06:13 PM   #5
Opps my bad.
Old 03-22-2013, 06:18 PM   #6
OK thanks a lot. I have checked everything and it seems OK. Just to be clear if I wasn't, the gfci is NOT tripping, it's the breaker in the panel. I'll check the grounds.
Old 03-22-2013, 06:22 PM   #7
It is for a sump pump which would run all the time if I just plugged it in. The GFCI is not tripping but the breaker at the panel is. Unless, as Speedy Petey said, there is a ground line touching neutral or hot (really don't think so) it doesn't make sense.
Appreciate you replying
Old 03-22-2013, 06:25 PM   #8
Why would you want a sump pump on a switch!!
No float?
Old 03-22-2013, 06:29 PM   #9
No float?
Good question. It's a bad design because near the top of the pump is the water table. Due to this when it pumps water the hole immediately fills up. I use it to flush out water if it gets too high but normally just leave it if the water level in the hole is stable.
Old 03-22-2013, 06:34 PM   #10
Another site suggested sending the hot line from the switch to the "load" side (brass) of the gfci and then the neutral from the line side through the switch unconnected and back to the panel. This doesn't seem right and is not what I did, as I only used the line side of the gfci.
Old 03-22-2013, 06:56 PM   #11
TTW
TTW's Avatar
Hope this helps, switch the black LINE wire. Is there anything connected to the load terminals?
controlling a gfci outlet with a switch-outlet-switch-electrical-diagram.jpg
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 03-22-2013, 06:57 PM   #12
TTW
TTW's Avatar
Nope, this makes no sense.
Old 03-22-2013, 07:20 PM   #13
Rewards Points: 166
Maybe I'm crazy, but wouldn't it be easier to just elevate the pump in the pit a little? Maybe put a couple bricks under it or something.
I'm no plumber, so maybe that's a stupid idea, but a sump pump is really meant to be automatic. What happens in you are away on vacation and a major storm hits?
dftc is offline   Reply With Quote
Old 03-22-2013, 07:40 PM   #14
TTW
TTW's Avatar
Edited my post due to wrong info.
Old 03-22-2013, 07:44 PM   #15
Thanks TTW. No it's dedicated. Intrigued by the switch loop and its neatness. Think my set up is not wrong but I like yours a lot splitting up neutral and hot. Perhaps that is what the gfci is hoping for.
The Following User Says Thank You to libbysorcum For This Useful Post:
Msradell (03-22-2013)
Rewire a switch that controls an outlet. z00ropa Electrical 8 10-23-2012 06:00 PM
will this GFCI outlet setup work collegetry Electrical 4 10-16-2012 08:49 AM
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 05:02 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
